How many miles on your 2.4 ss?
Only thing Ive had to due was struts they weren't that bad I just upgraded to the fe5's added about 2* of caster it's really responsive now my car has had either 100 shot of nitrous or boost since 6,000 miles
About 88k on my 07 now, parts list:
24k: M62 on
45k: New sway bar end link, Driver side
48k: gas cap
54k: M62 off
80k: Passenger sway bar endlink,
80k: EVAP purge valve
81k: Power steering motor recall
83k: Left front wheel bearing. Covered by 100k powertrain warranty
Not much to complain about there!
24k: M62 on
48k: gas cap
54k: M62 off
36k miles... just got an entire new F23 trans under warranty about 2k miles ago cause my second gear completely quit. Had my front air bag sensor die about 10k miles ago so they replaced that. Other than that, pretty smooth sailing.
I have 35k on my 2006. Both front struts and wheel bearings needed to be replaced at 30k. Warranty covered it with no hassle. Other than that, no problems at all so far.
EDIT: I need to do the front brakes bad. The stock rotors are HORRIBLE.
Last edited by Slupot; 01-09-2011 at 06:19 PM. Reason: Forgot to mention a problem
37k Not a single issue once. Replaced the power steering motor at 30 but it was working fine when i took it in. Dealership suggested it, plus it was free. Waiting for my struts to go on account of the Sportlines
when did you take it in to get the motor replaced? i still havent done it...
I got Tasha @ 54xxx miles.
Previous owner:
replaced steering column lock
power steering recall
windshield replacement
me: nothing so far. I need to replace my front sway bar end links. I'm at 685xx miles.
Previous owner:
08 Sport, bought 09/08/2008. It's got 32000km's and the only problems I have with it is a sway bar that makes a ton of noise when it's cold in the winter and my A/F is off so I need to get a tune this spring.
ugh yeah, my warranty has been up, so il just have to go up there and see what they can do about it...
65xxx miles no problem engines wise. but some thing with the clutch sensor. that i replaced at 64xxx. but i just ingnor it. hey does anyone know why it keeps reading the CLUTCH PEDAL POSTION SWITCH. CODE IS P0833. CAN SOME ONE HELP?
im at 48,321.... my fuel tank evap thing went out along with my ECU, it had to be re-flashed... my driver side lock switch... my left rear hub... thats if for now.... lol I had to pay 350 for the evap sensor because none on my warranty's covered it.
2006 SS/NA 123,6xx Miles
Only thing thats failed was both front wheel bearings about 5K miles apart. car was over 100K miles.
I've replaced the Struts/Shocks due to springs (normal wear anyways)
Endlinks ( they always end up junk after you take em off to do the struts so i changed em while i was there)
and brakes, O/C's andtires, but thats all normal wear and tear. steering motor wass replaced last spring under warranty.
Oh i've broken 2 clutch switches that affect teh Crusie Control.
