How many miles on your 2.4 ss?
Old 01-19-2011 | 09:56 PM
  #51
07sscobaltss's Avatar
89k, going on 90, only problem is steering shaft nuckle make a nice clunk on every bump, and its an 07
Old 01-19-2011 | 10:05 PM
  #52
almost all injectors tick, mine do, and have been since i got it, my brothers 09 acura tl ticks too
Old 01-19-2011 | 10:08 PM
  #53
That-MyMy-Kid's Avatar
Just turned 40k. Borderline mint condition on the exterior. Has plenty of kick left in her
Old 01-19-2011 | 10:09 PM
  #54
samsumthing's Avatar
50200 miles so far. 30k wheelbearing went, somewhere around there the sunroof broke, 42k exhaust cam actuator solenoid went, steering shaft has been replaced somewhere in there and that was before the recall, and just replaced the brakes recently.
Old 01-19-2011 | 10:24 PM
  #55
DFZ24's Avatar
43k miles, 6k miles boosted, power steering recalled, tires changed, brakes changed, <(regular wear)
clutch being change this weekend <(boost fault)
Old 01-20-2011 | 12:41 AM
  #56
CordiaDOHC's Avatar
Get it checked out it might need replacing. Elco replaced my steering shaft for me due to a clunk and found damage to the steering shaft.
Old 01-20-2011 | 07:44 PM
  #57
jfowler55's Avatar
mine is a 07 2.4 with a 130,000 and i lost the transmission, the strut mounts, the flex pipe, the timing chain, sway bar bushings, stearning and stearing pump and a number of front rotors and there are too many noises to think of now but still running strong ahahahaha
Old 01-20-2011 | 07:57 PM
  #58
Mindrot's Avatar
86,000mi
Non-Aftermarket Related:
Thermostat died
A/T Shifter broke
Steering Column Replaced
Primary o2 Sensor died
Variable Cam Sensor died
Power Steering died
Old 01-24-2011 | 09:43 AM
  #59
munit06SS's Avatar
33k on my 06
no issues yet
Old 01-24-2011 | 10:46 AM
  #60
Drew.4L's Avatar
then i have nothing to worry about, mines an 08, it doesnt really tick as loud, unless the hoods open of course.
Old 01-27-2011 | 02:33 AM
  #61
Stick's Avatar
I got an 07 SS 2.4. Mine's at almost 90,000 miles, had to replace the cat at around 70,000, other than that, no problems at all, other than a small leak into the interior, not bad though..
edit: Just got word I need to replace my clutch, time for a stage 2 upgrade
05-28-2022 03:47 AM
bigdeertz
11-17-2016 09:41 AM
HEATON
10-16-2015 07:21 PM
patooyee
10-15-2015 05:11 PM
grampss
09-27-2015 08:51 PM
Quick Reply: How many miles on your 2.4 ss?
