how much psi?
what does everyone recommend for the 2.4? like what size pulley would be best for a DD? for it to still be safe and reliable. i know i will have a good tune through trifecta so im not worried about that
ideally you would see anywhere between 13-16psi of boost on a 2.8. However, you are also spinning the rotors at a faster rate, so you would most likely get heatsoak a lot easier. On your whip, xander, I would recommend not going over 12 psi on your internals. A 3" pulley would be fine, but it's really up to you.
Being tht ur a 2.4 u'll be around 12 pounds on a 2.8 pulley. We ain't the same as the lsj motors, they get like 16 pounds on that set up. Ima doin a 2.8 and with NICE mods lol and I'm fine and running perfect. Ppl who go and blow there motors are the ***** that can't drive or the ones tht throw a 2.6 pulley with no supporting mods
well i have a 2.8 on the SC set up i got. it has opt b. ready to go with a aftermarket h/e. i have a CAI and i already have 2.5" catless exhaust. i just bought a 2.9" though. ill run that one first and im auto
