How much torque for valve cover bolts?
Old 07-28-2010 | 12:12 AM
veilside's Avatar
Hi guys,
I will need to change my valve cover gasket and I want to know how much torque should I give to the bolts for the engine cover?
Do they need to be very tighten when I'll put the valve cover back on?
I know the bolts aren't the strongest so that's why I'm asking the question and I need to change the gasket because of oil bleeding on the passenger side.
Thank you!
Old 07-28-2010 | 12:13 AM
EcoTecDriver's Avatar
I think its 10inlbs but dont quote me its been awhile, and my manual is in the garage.
Old 07-28-2010 | 03:46 AM
slobalt08's Avatar
dont bother i ended up breaking a bolt in the head torquing them so i said F it
Old 07-28-2010 | 04:16 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Ha, yeah... I was going to say... not very much. I broke like 3 when I put my Valve cover back on.
Fkn idiot, I was. I snapped the first... and said, "Okay, not that much pressure". Then the second one snapped... and that's why my Fuse Box Cover is cracked. I think I yelled "God Damn It!" And slammed my hand on it. I then had to yell another GD.
Old 07-28-2010 | 06:09 AM
AcesNEights's Avatar
Its 10 in-lbs.
So basically like finger tight lol
Old 07-28-2010 | 08:44 PM
veilside's Avatar
Ok thanks! So basically, I don't need to put that much force to tighten the bolts right?
Old 07-28-2010 | 08:57 PM
I finger tighten them, then bout 1/4 turn of the wrench
yup! just till its tight
Old 07-28-2010 | 09:01 PM
ericgt79's Avatar
torque schmorque! tighten it to German specs.....GUDEN TIGH
Old 07-28-2010 | 09:02 PM
Old 07-28-2010 | 09:47 PM
veilside's Avatar
Thnaks guys for the help! It's appreciated!
Old 07-29-2010 | 09:04 AM
Illini_06SS's Avatar
I just snug them with a 1/4" drive ratchet.
Old 12-04-2012 | 03:44 PM
cevansd's Avatar
OK so I've been trying to figure this out myself for a while. I have both manuals Chilton and Haynes, and in both of them it lists the torque for valve cover on 2.0L as 71ft/lbs!! There's no way thats right is there? I broke 2 bolts already and I was no where near 71ft/lbs. The torque for the 2.2 and 2.4 is 89in/lbs. I'm no mathematician but thats a huge difference....
Old 12-04-2012 | 03:49 PM
Powell Race Parts's Avatar
89 inch pounds for all the 6 mm x 1.0 bolts. NO MORE THAN THAT!!
Old 12-04-2012 | 03:52 PM
user 72239's Avatar
My buddy tightened his 10 lbs on one and it broke. Just finger tighten them and then snug it down. no need to get all buck wild
Old 12-04-2012 | 03:57 PM
10 ft lbs = 120 lb inchs. yup. snap.
Old 01-05-2013 | 05:50 PM
slobalt08's Avatar
I wouldn't bother i torqued to proper spec and stud broke in the head fml
Old 01-05-2013 | 10:52 PM
StevoElSupremo's Avatar
glad I'm not the only one.. I broke one as well nothings leaking though, I just tightened them down till they were "firm" and gave the wratched a light tap.
but yeah I snapped one.. the first one I put back
Zharrington_2010LNF
02-08-2016 01:43 PM
dennis69
10-20-2015 04:49 PM
Trav3480
10-01-2015 08:17 PM
SSLOW06
10-01-2015 07:21 PM
SlowSaturn
09-28-2015 11:03 AM
Quick Reply: How much torque for valve cover bolts?
