How to Remove your ECM (manual)
Old 04-28-2006 | 09:15 AM
GTP's Avatar
GTP
I saw a post in my Vector ECM tune thread about a removal install tip for the ECMs in our 2.4s. Mine is manual 2.4 SS so I will use my procedure for that. With some diagrams from Solsticeforums.com.
So here it goes:
1. First disconnect the battery in your trunk. Its easiest to unbolt the negative terminal and make sure you swing it clear of the positive terminal and let it hang free.
2. Our ECMs are located under the hood right near the washer fill and radiator overflow containers under a small black shield.
3. You'll need to remiove this shield by simply lifting straight up and it will pop off.
4. Next thing to do is to remove the harness plugs. The below diagrams show how to remove the plugs and plugs tabs .
http://www.solsticeforum.com/forum/a...5&d=1142315561
http://www.solsticeforum.com/forum/a...1&d=1142378852
Once these are free, the ECM lifts right out and is ready to send to Vector..!!!
Old 04-30-2006 | 08:13 PM
savior's Avatar
thank you for posting this, i was wondering how to remove this- you'll see my order sometime soon
05-28-2022 03:47 AM
GaryGibblez
01-14-2020 10:35 AM
Solaris99
28
03-15-2017 01:22 PM
OrangeCoba
10-01-2015 10:00 PM
Tupp
09-30-2015 08:18 PM
Quick Reply: How to Remove your ECM (manual)
