I want to go turboed
Old 01-11-2011 | 11:58 AM
  #101
Dragonsfire12345's Avatar
Originally Posted by Ryan@zzp
I just saw the thread so I thought I would chime in. Def. don't twincharge. Next get rid of the LSJ intake, they are garbage. The plastic intake won't break. The 256ext will work great, but the 252 will be better suited for you power goals. The tranny will hold up great until you put slicks on the car. Take it easy on the tranny and it will be reliable until about 375- 400whp. If anything, over intercool and keep your piping to a max of 2.5". You should just use a 2.4 throttle body. Drive ability will be better and you don't need anything bigger until about 650whp. Sorry if I was to late with the info, haven't been in the 2.4 section lately.
thanks alot your not late this is one of the reasons I put this up way before I actually buy stuff that way I can make sure I get all the info I can get.
Old 01-11-2011 | 06:00 PM
  #102
Slay's Avatar
Our kit will work fine and you won't have any trans issues until the power is considerably higher than stock. Your car is about 140whp n/a and even at 300whp you will be fine. If you use a little common sense when driving your trans will hold up just fine.
Awesome, appreciate the feedback. I actually browsed zzp for a few last night and this morning. Re-looking at it, because I'm not sure what specifically I need to just "bolt on" and go. Any linking would be appreciated.
Edit: Found the supercharger bolt on, still looking for the turbo.. I must be blind.
Edit: Ah, finally found it. Anyways, so pricing for a turbo kit stage 1 runs 2k? Maybe I should start with CAI first :/ OR would a -cheaper- route be buying a stock TC off of someone from a SS?
Old 01-11-2011 | 07:23 PM
  #103
Spanky's Monkey's Avatar
if you want real power then you better go for broke. you'll end up there one way or another.
Old 01-11-2011 | 10:20 PM
  #104
Slay's Avatar
Well, still paying it off :/ So can't go for broke just yet. Bank wouldn't like me modding a car that isn't technically mine yet. Just want a decent ~50 hp increase really. 300 is a bit overboard with me and stuck with a budget of about $700 :/
Old 01-12-2011 | 08:53 AM
  #105
Ryan@zzp's Avatar
Don't pc. together a kit. Your best bet would be to buy the stage 2.
Old 01-12-2011 | 11:35 AM
  #106
flyy's Avatar
I just ran across this thread and I have to say, thank you.. lol I was so lost as to auto trannys along side a turbo, didn't know how our auto trannys would fair. Although I do have a 2.2l LS so are the trannys any different or are they the same, hmm maybe i should just wiki it :P but i was planning on just going SC or TC because of the easy maintaining but now i've reconsidered. I want at least 300+ hp with my car. So what would be the best route for me since I have a 2.2?
Old 01-12-2011 | 11:40 AM
  #107
kxrida2000's Avatar
^ Engine internals and a zzp kit with the s252 and u would be happy the cost adds up though trust me but if u stay under 250 u don't necessarily need to do engine internals such h as rods..pistons..valvesprings for the most part those are the weakest links in the 2.2 and the valve springs aid in high revving
Old 01-12-2011 | 11:49 AM
  #108
flyy's Avatar
Okay so if I did decide to go for 300+ I would absolutely have to upgrade engine internals? But if I just go for 250 and then decide that it's not enough power for me I could always just order the internals anyway and just up the boost and such afterwards for more power correct?
As for the 250 HP thought what all would I need for that, just the stage 1 zzp kit and I'm good to go or what?
EDIT: Sorry if I'm asking a lot of questions. I'm still very new at all this but I'm starting to really enjoy the whole aspect of it
Old 01-12-2011 | 12:28 PM
  #109
Ryan@zzp's Avatar
I would only consider the stage 2 or 3. You don't need to upgrade the short block internals even at 300whp. To get past the 300whp mark I would recommend valve springs. The bottom end is plenty strong at 300whp. Anyone doing a high compr. engine with a turbo needs to have some attention to detail, no half assing going on. Keep the boost in check, always run 93oct or better. The excuse that I let my girl drive my car and she put 87 in the tank is no ones fault but your own. Never over look the tunning. If you can't tune have someone that is experienced handle the job, not your neighbor that said he can. Find someone with proof that they have knowledge. Your motor will live to see many more days if you can just get this stuff figured out. Oh yea don't forget to do your oil changes.
Old 01-12-2011 | 12:29 PM
  #110
the auto trans is the same 4T45E, just install a aftermarket trans cooler and you will be good.
Old 01-12-2011 | 01:54 PM
  #111
kxrida2000's Avatar
Like Ryan said its not absolutely necessary to change internals at 250+ but your starting to have a pretty big chance of breaking something but yes don't do the stage 1 I would definitely go stage 2 or 3 with an s252 if u want a fast spooling Turbo...the s256 is a good Turbo which I have it just take a little longer to spool but I had a higher power goal that 300 so that's why I went with the s256et but listen to Ryan as he is a very smart guy but i can help u out for the most part with any questions u need helped out with
Old 01-12-2011 | 11:00 PM
  #112
flyy's Avatar
Ok so this is @Ryan, would I be able to order a stage 2 or 3 kit to come with the s252 instead of the s256? Since I'm an auto tranny I need something that is going to spoil up very quickly considering that I can't keep the boost where I need it against say another turbo with a manual tranny but you already knew that is this the reason for the s252?
Old 01-13-2011 | 01:21 AM
  #113
with a high stall torque converter the s256 is perfectly fit for a 2.2
yo, flyy are you trying to roll race? or is this from a dig?
Old 01-13-2011 | 01:41 AM
  #114
flyy's Avatar
Honestly, this is just for fun always wanted to make this a hobby of mine. BUT, I still know what I want with the 300+ HP.
Old 01-13-2011 | 08:27 AM
  #115
Ryan@zzp's Avatar
The 256 spools plenty quick in the auto and boost will never fade between shifts like manual, (of course there are ways around that). The 252 will support all the power you will need and will spool noticeably faster than the 256. Both have great power bands but if I had to chose between the two for a quick spooling, good gas mileage, light to light car it would be the 252. If you wanted a highway killer than maybe the 256. At the boost levels that most of the 2.4, 2.2 guys are running the 256 is a little over kill. Again it is all preference. I am used to bigger turbos with more lag but the power goal is higher in most cases so there is a trade off. I did love driving our blue car though, it spooled fast and I didn't have to shift That car needs to be turbo again, wait maybe it's going to be
Old 01-13-2011 | 09:31 AM
  #116
i like how you point this out ryan and initially customers were not given a chance to order the s252 when zzp first started selling the stage 2 turbo kits for 2.4,2.2 guys. this makes me laugh when i think of the low/mild boost numbers we're pushing for the turbo size when the s252 should have been the first option apparently. i love my zzp stage 2 turbo kit but i did have to change a few things to be completely happy with it..
Old 01-13-2011 | 10:49 AM
  #117
flyy's Avatar
So you do actually sell the 252 along with the stage 2 and 3? If so how do I select that, do I have to call and ask for it? Also how much of a difference do the 60# injectors make and would I even need 60's?
What did you have to change?
Old 01-13-2011 | 12:24 PM
  #118
i run an fmic with custom pipe and switched from the 6mm zzp supplied vacuum line to the proper tial recommended 4mm vacuum. boost gauge reads more accurately after the vac line swap.
Old 01-13-2011 | 01:21 PM
  #119
flyy's Avatar
whats fmic?
Old 01-13-2011 | 04:48 PM
  #120
yellowss7590's Avatar
you want a good manifold then look for a Saab one that will fit your car they flow really really good.
Old 01-13-2011 | 04:51 PM
  #121
@ flyy its FRONT MOUNT INTERCOOLER lmao.
Old 01-13-2011 | 06:29 PM
  #122
flyy's Avatar
lol that's what i figured
Old 01-13-2011 | 06:45 PM
  #123
yea op best bet go zzp kit best route you get all the parts ect and top quality
Old 01-13-2011 | 11:34 PM
  #124
definately and saves you headaches trying to piece everything together.
Old 01-14-2011 | 01:20 AM
  #125
flyy's Avatar
Yeah I'd rather not pc anything together and not to mention even ryan recommended not to pc one together either and just buy a kit so that's what im going to do haha. I do have another question though.
@Ryan does the kit come with eveything I will need or are there things that I need to buy separately, like maybe a 2.4l tb since I have a 2.4l IM?
Quick Reply: I want to go turboed
