Injectors
Old 07-10-2007 | 06:02 PM
langzhihun's Avatar
Injectors
Hey guys, I hear all this about installing the 2.0 S/C injectors, I went to the dealer and they said that they could do the "Stage II" upgrade which consists of a Pulley and Injector upgrade. He told me that we wouldn't be able to do the pulley, but GM could upgrade the injectors and Tune the ECU.
So the question is... Is this for real? Are the 2.0 stock injectors better than GM's upgraded injectors or what?
Old 07-10-2007 | 06:05 PM
blackngold20's Avatar
why would the stock injectors be better than the upgraded injectors?? key word upgraded. Ofcoarse not. But how is the dealer gonna tune your 2.4? I didn't know that they did tune 2.4's
Old 07-10-2007 | 06:08 PM
SilverBalt13's Avatar
You cant but a Stage 2 kit for the 2.4. The injector harnesses are even different. The dealer is retarded.
You wouldnt need 42# injectors in the 2.4 unless you are running boost. The stock 2.0 injectors would be enough for anything you are doing.
Last edited by SilverBalt13; 07-10-2007 at 06:08 PM. Reason: Automerged Doublepost
Old 07-10-2007 | 06:13 PM
XM15's Avatar
If the dealer said that they would give you the stage 2 injectors, they would be 42 lbs/hr, not the 32? lbs/hr that the stock ones are. The upgraded ones would be too large for your setup.
Also, I didn't know that GM offered a flash for the 2.4. I think the dealer was getting confused again.
Old 07-10-2007 | 06:15 PM
Ya the dealer was thinking the Stage 2 kit would be compatible with the 2.4 if they didnt put the pulley on. God I would love to see the look on there face when they realize they messed up haha
Jimmys2007CobaltSS/C's Avatar
off the subject.....Are u dominican?
Old 07-10-2007 | 06:45 PM
langzhihun's Avatar
No i'm not dominican. And i do plan on boosting in the future after i save the money. And i think the dealer is retarted too.
05-28-2022 03:47 AM
DarrenGC
12-24-2021 01:55 PM
Sl0wbaltSS
11-21-2018 11:11 PM
patooyee
10-15-2015 05:11 PM
yellow dragon
09-28-2015 09:49 PM
Quick Reply: Injectors
