Injen intake rattle?
Old 06-10-2008 | 05:40 PM
xBuRnTx's Avatar
Hey gang,
I recently installed the Injen intake on my G5 GT....Got a couple questions for you. Has anyone else experienced a pretty loud rattle when they turn on their car, coming from the wheel well, made by the intake? Also if anyone else has an extremely tight fit with their intake, rubbing when it enters the wheel well and just above the headlight? thanks guys...oh and maybe a possible fix?
Old 06-10-2008 | 05:56 PM
Skrilla's Avatar
I dont have the rattle but i do have the fitment problem. I had to stuff a rag in the hole to stop the rubbing. On top of that the bracket with the rubber bung the thread part snapped so thats no longer usable All in all poor fitment and quality on the bracket. Sounds angry as hell though Just put the hydro shield on it yesterday aswell.
Old 06-10-2008 | 06:28 PM
xBuRnTx's Avatar
Yah, it does sound great. But pretty loud rattle on startup I guess from engine moving a lot..but then nothing after that..I guess I will have to deal with it...
Old 06-10-2008 | 06:55 PM
Skrilla's Avatar
Could be that the rattle you here is the intake piping hitting the car somewhere (?) Just a thought. does it rattle when you rev it hard?
Old 06-10-2008 | 10:20 PM
xBuRnTx's Avatar
Yes that's what it is I believe, mainly hear it when I initially start the engine. Doesn't seem to be noticeable when I step on it...and Sometimes when I turn my wheels all the way to the left it vibrates the intake in the wheel well...Infact I know it's rubbing the body of the car, where it enters the wheel well and as well just after the first elbow to the right of the headlight..Just checking if anyone else has problems with this intake being such a tight fit, and if they did anything to fix the problem? and free up some space for engine movement?
Old 06-10-2008 | 11:22 PM
nhanson's Avatar
stick something in between like foam or some rubber or cloth....
get some better motor mounts to stop the shaking!!
Old 06-10-2008 | 11:28 PM
b_faulk75's Avatar
Mine does rattle, only on start up. Funny you should post this, i just noticed it today and it's been on a while. I put a piece of 2 sided tape on the the pipe where it was touching the body and that helped...
Old 06-10-2008 | 11:30 PM
hoffa's Avatar
i bet it's the piping hitting/rubbing against the hole going into the wheel well
Old 06-10-2008 | 11:34 PM
b_faulk75's Avatar
Old 06-10-2008 | 11:59 PM
xBuRnTx's Avatar
yah I am pretty sure it is..Howcome it would be doing that? Shouldn't it fit better? Or is that intake not made for the 2.4L, I'm pretty sure it is though...
Old 06-11-2008 | 12:32 PM
Ducky22287's Avatar
Probably hitting the car. The two spots I had trouble with were right in the front where a little piece of metal juts out and in the hole where it enters by the splash guard.
Old 06-11-2008 | 04:55 PM
xBuRnTx's Avatar
Yah I'm having troubles at those spots as well, where the body of the car curves above the headlight, as well as the whole where the resonator was...bugger...Should I just convert it to SRI? Would I still get the same sound? and Will it affect performance at all?
Old 06-11-2008 | 08:06 PM
Ducky22287's Avatar
I used these rubber guards. I can't copy and paste cause im on my phone. I made athread about the problen in the 2.4 tech disscussion. do a search using injen. I posted pics of what I did. cold air is the way to go though.
Old 06-11-2008 | 08:12 PM
xBuRnTx's Avatar
Great thanks, I'll look it up! I mean on one side of the tubing there is loads of room, but then the other side it basically resting against the body of the car, it sucks.
Old 06-11-2008 | 08:21 PM
hoffa's Avatar
i re-adjusted all the fittings starting from the TB. it's a guessing game, but i actually got it to work.
and the rubber spacer thinger (how retarded looking it may be) actually does sorta work.
Old 06-12-2008 | 01:12 AM
Ducky22287's Avatar
https://www.cobaltss.net/forums/show...ighlight=injen
^^That's the link to my thread a while back.
Old 06-12-2008 | 01:28 AM
marty20sc's Avatar
use a fuel line or something close to it cut down the middle and wrap it around the metal hugs the metal good to looks much more visually appealing solved my rattling
Old 06-12-2008 | 05:58 PM
xBuRnTx's Avatar
Great I'll give that a try! Just hope I can get it in place before it rubs too much I get a hole in the intake....eeeek!
05-28-2022 03:47 AM
no_ss
10-18-2015 11:58 PM
717ssbalt
10-02-2015 04:01 PM
jimbofug007
10-02-2015 12:06 PM
OrangeCoba
09-25-2015 06:06 PM
Quick Reply: Injen intake rattle?
