Installed Jet Stage 2 this morning. Thoughts
Old 06-19-2008 | 10:21 AM
SI FTL's Avatar
Exclamation Installed Jet Stage 2 this morning. Thoughts
Ok, so i got the chip and put it in this morning after work. (Took all of.. uh.. 2 minutes with disconecting the battery) Started right up fine, no lights. I started backing out of my drive way and my powersteering started to skip, tug a little bit. Ahh ****. As i was going down the road i was thinking, this chip isn't doing ****. And it felt like i wasn't doing anything. I am running 91octane with this stage 2. So, i went to mcdonalds for some breakfast and sitting there.. at idle in neutral, Car dies.. No sputter.. no warning.. no anything. So, i started it back up. Once i got into my town and on the backroads i figured i'd give it another shot before calling jet and bitching. Dig: Rpms climbed as it was in a hurry, first gear i hit my limiter almost instantly. 2nd still had some noticeable power, was suprised. 3rd gear held onto torque while i was inclining in speed. And then i had gone back to about 60mph. I can tell for SURE from a digg on first it took off like a banshe. My powersteering still twitches though.. Maybe it's because the wires for the connector for the ECM are so damn short i had to stretch the bitch to plug into the chip We'll see. I'm going for another dyno either tomorrow or monday.. Thoughts?
Old 06-19-2008 | 10:29 AM
MadBrad's Avatar
Dude, you would of been better off finding somebody with HP tunners, bought some credits and got a tune. That way you know what you are doing to your car. But you bought a little black box that you have no idea what was done to it.
Old 06-19-2008 | 10:31 AM
SI FTL's Avatar
Dude, I've got a 2008.. No Tunes support myplatform as of yet. And at least with this, it pops on and off. "BOX TUNE, NO BOX TUNE" Some members wanted to know so i figured i'd buy one. I don't feel to comfortable with someone tuning my car just as of yet anyway.. But i'm sure as soon as HPT breaks it.. i will be getting it lol
Old 06-19-2008 | 10:33 AM
Zdeuce4's Avatar
Wut'd u get baseline? im interested to see wut u make now...
Old 06-19-2008 | 10:35 AM
rhanes216213's Avatar
I think that the chip mod is a bad choice. The tune would have produced more and much safer for the car. Hope that HP comes out with some thing for you guys soon.
Old 06-19-2008 | 10:36 AM
SI FTL's Avatar
Before Chip, With the mods i have currently (minus the DP I have now) I put 166 to the wheels. (with my shitty ass GM tune) I mean.. which is low But seeing the car comes stock with 173 crank (everyone has diff numbers).. Wasn't to bad
Originally Posted by rhanes216213
I think that the chip mod is a choice. The tune would have produced more and much safer for the car.
AHh yes, again.. no tune for my 2008 as of now. But how do you figure it would be "safer"?
Old 06-19-2008 | 11:33 AM
OrngBalt's Avatar
Did you also get the 180* thermostat? I believe that you are supposed to run this module with 89 not 91.
Old 06-19-2008 | 12:26 PM
SI FTL's Avatar
stage 2 has to run with high octane. Look it up www.jetchip.com
As far as the thermostat, no i have my stock one. It's 180 or around there anyways as of right now. It's not manditory.. My temps have been keeping the same.
I re-installed chip after speaking with jet.. so far all my problems have gone away. They say to put 150 - 200 miles on it and i'll see all real gains. Dyno will tell the truth tomorrow hopefully!
Old 06-19-2008 | 01:16 PM
OrngBalt's Avatar
My bad, you are right. They do say it is designed to work with the 180 thermo tho. I really want to see dyno results. Have you dyno'd before or are you going to dyno with and without it tomorrow?
Old 06-19-2008 | 01:25 PM
CobaltSS 16's Avatar
Curious to see the results. As long as your problems go away, I would say good buy.
Old 06-19-2008 | 01:28 PM
originaladrian's Avatar
subscribed, def interested if you put some noticeable gains on paper
Old 06-19-2008 | 03:52 PM
BigEMU1's Avatar
Been curious about these. Subscribed.
Old 06-19-2008 | 06:41 PM
Red07SSNA's Avatar
It is interesting that you had power steering problems -- the module doesn't affect this and since it is electrical the engine RPM shouldn't affect it either unless you might have had a bad/weak battery connection.
Keep us informed of the reliability. My Stage 1 module is still working nicely -- for more than a month. If you show some real numbers on the dyno I would be interested in having both modules to try out myself.
Old 06-19-2008 | 09:11 PM
SI FTL's Avatar
Yeah, I spoke with jet and told them my issues. I also had some rpm flutters at idle (jet told me their product works over 1,500 rpm) So i took it back out and re-connected it again and so far everything has gone away. I'm not to pleased with how much i had to stretch the factory wiring harness to the ecm and chip. But yup, I'm thinking i've made OK gains with this plug in. Like i said I'm going to run it on the dyno again Hopefully friday, if not tues/wed. I'll let you all know for sure!!
Btw.. Dyno last time w/o chip 166 to the wheels
can't remember torque..
Old 06-20-2008 | 04:35 PM
omgshesaboy's Avatar
did you dyno?
Old 06-20-2008 | 07:24 PM
eazyasone23's Avatar
interested to see the results
Old 06-23-2008 | 01:07 PM
OrngBalt's Avatar
Xtorted.... whats the result? you get dyno'ed?
Old 06-23-2008 | 01:25 PM
Zdeuce4's Avatar
dang everybody that gets these, say they will dyno or run at the track and the thread just dies
Old 06-23-2008 | 03:31 PM
OrngBalt's Avatar
in all fairness he said he was getting dyno'ed friday or tuesday depending when he was able to.
Old 06-23-2008 | 06:30 PM
Zdeuce4's Avatar
oh definitely.. im just saying im subscribed to pretty much everyone that's gotten the jet chips and they end the same
Old 06-23-2008 | 09:59 PM
OrngBalt's Avatar
^^^ I know... I was one of the first to push this module. I even started a couple of the threads and was in contact with the company multiple times. I just wanna see the hard facts
Old 06-23-2008 | 10:04 PM
boostedss26's Avatar
subscribed
Old 06-25-2008 | 09:13 PM
scottyguy401's Avatar
It's wednsday, where's the results???
Old 06-25-2008 | 09:18 PM
mkulrey13's Avatar
Why spend the money.. all it is is a resister inside a box... i can do that with 99 cents and a radio shack.
wtf this is gay
Quick Reply: Installed Jet Stage 2 this morning. Thoughts
