intake manifold single pass
Old 02-13-2011 | 02:44 PM
Dragonsfire12345's Avatar
gonna take my intake manifold tomorrow to the machine shop so they can rig up a single pass setup. My question is, which way does the water flow through?
inlet: lower passenger side, outlet: upper driver side? or vice versa???
I figure this would be the best way ensure all laminova cores are filled with fluid.
Old 02-13-2011 | 02:45 PM
slvr 04 rl's Avatar
thought you were going to go turbo?
Old 02-13-2011 | 02:56 PM
I do, but I don't really wanna spend $2k plus for different type of FI.... even though I'll make some of it back from selling my sc kit, and other parts I wouldn't need anymore.
Old 02-14-2011 | 12:30 PM
manifold is at the shop, I'll have it back on Thursday.
Old 02-14-2011 | 07:20 PM
Drew.4L's Avatar
stock manifold? jw
Old 02-14-2011 | 07:46 PM
laser_racer's Avatar
Damn took them hour to cut mine are they welding it up also?
Old 02-14-2011 | 08:03 PM
it has a dual pass on it right now.
and yes they are gonna weld the compartment on the alternator side as well.
Last edited by Dragonsfire12345; 02-14-2011 at 08:03 PM. Reason: Automerged Doublepost
Old 02-14-2011 | 08:22 PM
They welding up the end plate that comes off also?
Old 02-14-2011 | 09:55 PM
I figure on using all 3 as outlets
Old 02-15-2011 | 08:43 AM
That might not a be a good thing seeing the inlet is not bigger then just one hose. It sounds like if you do that you will e only getting flow to the fitting with the less resistance. Kinda like only the bottom core will be getting the most flow. Might want to think about it might find out it would hurt to run it that way.
Old 02-15-2011 | 11:02 AM
another question, how would the fluid from the lower 3 sections exit out the top since the endplate is sealed from each other?
Old 02-15-2011 | 11:15 AM
Your suppose to cut the plate and weld all of the chambers together. Then send it thru the fitting opposite of the lower passenger fitting.
Old 02-15-2011 | 11:44 AM
could I use a dremel to open up the chambers in the endplate together? I know it would probably take a while lol
I could even use a dril bit
Old 02-15-2011 | 11:48 PM
You have to weld the top one to the center and I think same goes for the bottom piece.
DarrenGC
12-24-2021 01:55 PM
01-12-2016 12:01 AM
no_ss
10-18-2015 11:58 PM
10-13-2015 09:32 PM
09-26-2015 06:44 PM
Quick Reply: intake manifold single pass
