interceptor and boost question
Old 10-22-2013 | 11:21 PM
qwank's Avatar
Will an interceptor read boost on a superchargered LE5?
Old 10-22-2013 | 11:22 PM
nhanson's Avatar
Sure will!
Old 10-23-2013 | 08:42 AM
Avalanche687's Avatar
Works 80% of the time all the time.......yeah it'll work just fine
Old 10-23-2013 | 08:55 AM
noorj's Avatar
only if you put in a 2 or 2.5 bar map sensor
Old 10-23-2013 | 10:00 AM
qwank's Avatar
ok, I'll be running a 2.5 bar.
I was trying to figure out if I should get a single or dual interceptor, but I think I'll still get a single and go with a manual boost gauge also.
Old 10-23-2013 | 10:04 AM
noorj's Avatar
Yeah my setup is ZZP 3 gauge pillar with boost, interceptor and wideband then steering wheel bezel with EGT. Since our cars don't have a factory wideband like the LNF I think dual interceptors is pointless
Old 10-23-2013 | 06:08 PM
mtbrent's Avatar
How are you all getting an interceptor to read boost with an ecm that doesnt read boost?
Old 10-23-2013 | 07:03 PM
nhanson's Avatar
Because its a MAP sensor...
Old 10-23-2013 | 09:16 PM
noorj's Avatar
The pcm can "read" boost but the ve map only goes up to 100 kpa therefore cannot provide fueling for boost.
Old 10-23-2013 | 09:17 PM
nhanson's Avatar
and welcome to MAF tuning
Old 10-23-2013 | 11:29 PM
mtbrent's Avatar
interesting. i had a 2.5 tmap from lsj on mine when it was supercharged, no interceptor reading for boost. Required mechanical boost gauge.
Old 10-23-2013 | 11:34 PM
qwank's Avatar
it was prob listed as manifold pressure
Old 10-23-2013 | 11:52 PM
mtbrent's Avatar
probably right.
Old 10-24-2013 | 11:45 AM
nhanson's Avatar
Pretty sure thats what it is...
turbochargedss2012
09-20-2023 12:17 PM
brandon04
10-21-2015 07:04 AM
nathan112i
09-30-2015 07:12 PM
Extremespeed
09-29-2015 04:34 AM
09-26-2015 06:44 PM
Quick Reply: interceptor and boost question
