Issue with idle any idea?
Please check the video.
The idle issue is that it goes up and down then finally sets to idle at 900rpm lets say
https://www.facebook.com/video/video...=2922946109525
TPS , accelerator pedal sensor, vacuum leak, dirty throttle body will all cause idle hunting.
No way to tell from here. Check codes first then move on from there.
sometimes you can check the tps sensor by disconnecting it .. if it doesnt cause anything... then its bad
go to chevy dealer and have them clean your TB... over time they get too dirty....
guys my tpms are not installed i have my winter tires and the traction control i isually take it off thats why these two lights were on.
The idle issue was since i went supercharged last summer so it must be something related to it probably the tune..
Does it happen more when the car is not warmed up? Does it happen more when the car is under a load at idle(a/c,lights)?
I have been trying to figure it out myself...I have a similar problem, but it happens to me maybe 1 in 10, not every time. It started happening since my build...I think the reason is the lighter flywheel. It spins down pretty fast and undershoots the idle, then recovers like yours. I will let you know what I come up with. I have a good idea where to start...just give me a few days. It is likely tune related
