JBP 2.4L VVT Camshaft Tester Needed
Old 10-11-2006, 04:45 PM
GTP
GTP's Avatar
Originally Posted by JBP
Yes, there are parts available for the 2.4L on our website (valvetrain wise). Boost cams are very simple to design based on initial profiling and indexing.
Thanks for the heads up.....
Any recommendations or future package deals for cams/springs/retainers?
What are redline recommendations with your:
Stage 1 Cams and Springs (with supporting mods)?
Stage 2 Cams and Springs (with supporting mods)?
Old 10-11-2006, 09:00 PM
celicacobalt's Avatar
thats what i like to hear, i guess you cant make them though until you have a boosted cobalt to test on though
Old 10-11-2006, 09:09 PM
spooler's Avatar
Yes, they will be making springs and retainers packages as well. Mev said everything should be solid Dec. 1st. Make your Christmas wishlists!
Old 10-12-2006, 02:20 PM
JBP
JBP's Avatar
Yes spring and retainers will be sold as a kit.
Old 10-12-2006, 11:45 PM
g5mike's Avatar
Well I dropped the cams off today and we went over a few things,first of all the path to be taken is going to be me driving for a week with the cams, then Ill tune and dyno(so be patient )gives the car a chance to adjust alittle first.secondly we all talk about gains,well the last ecotec cams they did was 26whp gain on a 2.2 cavi, he expects these cams to be more agressive with even better gains,and told me that they would class anywhere from stage1-2,wont know till the computer done doing its analyis,the cam is basically converted from a two to three lobe making it take in fuel and lift more accuratly this is gonna give awsome gains throughout the powerband,look for better than expected gains from this,the change in cams also classifies your vvti to vvtii-f,Ill post back as the info comes this thread would be more suited for the 2.4 section for all 2.4 members to follow
Old 10-13-2006, 10:59 AM
i bet wit these cams forced induction will become impossible...
Old 10-13-2006, 11:10 AM
g5mike's Avatar
I dont know enough to answer that,but I want an NA car anyways
Old 10-13-2006, 11:53 AM
GTP
GTP's Avatar
Well..uh..if your gonna spend $$$ for boost why bother spending close to another grand on cams. Just turn up the boost a few psi and tune it. Voila, no need for cams....
Old 10-13-2006, 12:02 PM
GTP
GTP's Avatar
Mike keep us posted on the hiney dyno once you start driving it.
Old 10-13-2006, 12:10 PM
g5mike's Avatar
sounds like a week from today I will start driving it,after a week or so of driving Ill dyno
Old 10-20-2006, 04:35 PM
  #36
Brandon97Z's Avatar
Times up buddy. Stop keeping us waiting
Old 10-20-2006, 07:45 PM
  #37
YoAdrian's Avatar
Just signing on to the thread. This sounds interesting.
Old 10-20-2006, 07:48 PM
  #38
g5mike's Avatar
STAGE2 TRI-FLOW cams have just arrived home,Ill be putting them on tommorro if not Sunday afternoon
Old 10-20-2006, 07:51 PM
  #39
NJHK's Avatar
What makes you think that?
Old 10-20-2006, 07:52 PM
  #40
g5mike's Avatar
forced induction is fine,the compression ratio is not affected either
Old 10-21-2006, 09:18 AM
  #41
UpOnGaMe's Avatar
so what are you saying is gonna be the b4 whp on your car (b4 install of cams)
Old 10-21-2006, 10:54 AM
  #42
g5mike's Avatar
since I will not be able to dyno run it before the cam installation a dyno from any of our cars(stock or intake catback) should be fine
Old 11-08-2006, 07:58 PM
  #43
Site Founder
JonyyB's Avatar
Moved to 2.4 per Mikeg5 who is working with JBP on this
DarrenGC
12-24-2021 01:55 PM
OrangeCoba
10-01-2015 10:00 PM
SSLOW06
10-01-2015 07:21 PM
Iceberg
09-29-2015 12:33 PM
09-26-2015 06:44 PM
Quick Reply: JBP 2.4L VVT Camshaft Tester Needed
