JBP VVT LE5 Camshafts
#51
man look those cams will wait, your friend needs you and thats more important then these cams.
Whenever you get to it you get to it. No rush as I dooubt anyone here has the cash in hand waiting to hear from you. And if they do they can wait.
#54
Does the starter engage but the engine won't turn over? Did you double check the timing chain position? Can you turn the engine by hand at the crank pulley? Did you connect engine ground wire? Just some ideas....
#55
#58
Mike, yes, The cam gear to camshaft bolts are torque to yield. Good practice says to change them; but the clamping force required can be extended to another use if need be. I've done enough ECO camshaft swaps to come to this conclusion. Plus, the fact that the bolts are pretty expensive.
If you need any help or guidance for your no start condition, just holler.
#59
Does the 2.4 have a cam sensor like the 2.0L? If that is not timed (slot correctly aligned) the car will not start. I had to re-adjust mine as it was reinstalled by the machine shop at a different timing place. The car ran perfect after that.
#61
#64
I have found that 2.2L cams do not work in the 2.4L (more on this later). Please make sure the cam you have installed is in-fact keyed for the cam sensor.
#66
I'm just offering ideas. Sometimes its the simple things that get overlooked.
#67
I pulled apart a 2004 2.2 to take a look at the cams. The 2.2 cams in that 2004 did not have a hex or any other provision for a cam sensor. My 06 2.2 cams did not have any provisions for a cam sensor either. I'm only offering ideas.
#69
LSX RWD S/C conversion
Originally Posted by Jackalope
Uh Oh this does not bode well for us 2.4 guys.
I'll be keeping an eye on this, good luck Mike.
#70
Originally Posted by victory_red_SS
This is not an indication of problems for the 2.4 guys, just those who get help from inexperienced friends to "re & re" the cams. Mike will be fine as he is going to get a shop to complete the install.
#73
The car is going in at noon tomorro,to the "cam guys" my bud droped the ball on me,otherwise I did to,its been one heck of a week,sorry to you Mev and all,gonna cost some bucks but otherwise it is gonna finally be done
#75
Originally Posted by Dragonsfire12345
good luck with the install, just curious did the shop give you a quote for how much it will cost to see whats wrong?
