JBP VVT LE5 Camshafts
Old 11-08-2006 | 08:22 AM
  #176
JBP's Avatar
JBP
Mike, Your performance shop called and I gave them guidance on head disassembly and some short cuts. You're guaranteed to have some bent valves as they did a leak-down and found a bunch of cylinders not holding. It'll be a while until you get your car back up and operational...
Old 11-08-2006 | 08:29 AM
  #177
3fo893013L's Avatar
The plot thickens...
Old 11-08-2006 | 08:40 AM
  #178
g5mike's Avatar
What do you mean by "AWHILE"???
Old 11-08-2006 | 08:44 AM
  #179
3fo893013L's Avatar
My guess is between 3-5 weeks.
Old 11-08-2006 | 09:02 AM
  #180
victory_red_SS's Avatar
LSX RWD S/C conversion
Well Mike, my engine has been out of my car "awhile"
Old 11-08-2006 | 09:08 AM
  #181
Jackalope's Avatar
3-5 weeks is a good guess. You figure the time to pull it and take it to a machine shop, then the head has to wait its tun on the shelf, they get to it clean it tear it down see whats bad and order the parts, wait for new parts to come in, reasemble and check it out, then ship it back and re-install it on the engine. Yeah I'd say 3-5 sounds about right, lean more toward the 5 cause its not a small block and parts aren't as avalible.
See you in January.
Old 11-08-2006 | 09:19 AM
  #182
Mike is the shop your car at now a complete shop where they can do everything in house?
Also I believe Mev said he has the parts in stock, did he not?
Old 11-08-2006 | 10:09 AM
  #183
panblackrose's Avatar
Ouch man, I feel for you. My car is in for oil, door handle, tires, and a tranny check. It may have only been yesterday that I dropped it off, but I miss it. They gave me a 4 door SS auto to drive.... fast, but I hate auto.... i want my car
Old 11-08-2006 | 10:15 AM
  #184
pjk91's Avatar
holy crap. i can't be without a car for 3-5 weeks! i'm definitely takin it to a shop right from the get go!
Old 11-08-2006 | 10:25 AM
  #185
MARIN007's Avatar
We all weap for your car Mike. Best of luck and hopefully this wont take too long to resolve.
Old 11-08-2006 | 10:27 AM
  #186
2K5SS/SC?'s Avatar
My new engine took awhile to get in (1 month), my clutch troubles took awhile to fix (1 month), and my headgasket blown took awhile to for me to break down and fix it (1 month). I'm saying a month!
Old 11-08-2006 | 12:18 PM
  #187
JBP's Avatar
JBP
Call the shop and ask for a time-frame Mike... I know what it takes to do ECOTEC heads from "bent valve land", and as Rod said, are they a one-stop shop or do they send stuff out?
It shouldn't take 5 weeks, sheesh, don't scare the guy. But for a virgin shop touching an ECOTEC the first time, it won't take a couple days thats for sure.
Have them check the piston crown edge for damage and ensure the combustion chamber has not received damage as well. ECOTEC guides always crush from the combustion chamber side first, then up. So you really have to check the guides for hair-lines and straightness at this point...
I believe you said your going with 2.2L ECO Ferrea springs, they won't fit. The head will have to be modified as the springs are about + 0.100" OD and will bind up against the oil frame.
Thats all that comes to mind now...
Old 11-08-2006 | 05:11 PM
  #188
g5mike's Avatar
Great news,I called the shop,and due to the fact that I did not turn the car,they are saying that it is just the valves,they will know more later today,he was saying that there is little damage only cause of the torquing that was done,there is also the chance that it might just be the intake valves, but I might as well replace all anyways,well Im feeling better than I was this morning BTW..Mev what valves should I go with?? and $$$$
Old 11-08-2006 | 05:22 PM
  #189
JBP's Avatar
JBP
Go with our one-piece stainless steel LSJ valves. They're respectively priced and a much better upgrade than stock.
Old 11-08-2006 | 06:05 PM
  #190
g5mike's Avatar
thanks Mev when I get the final word,Ill place an order with ya
Old 11-08-2006 | 07:10 PM
  #191
k2kwj's Avatar
im really anxious to do this..... i think that im doing the cams before the turbo.
Old 11-08-2006 | 08:00 PM
  #192
pjk91's Avatar
nice man. glad to hear the 5 weeks thing is out of the pic
Old 11-08-2006 | 08:41 PM
  #193
GTP's Avatar
GTP
Why? You should just spend the money on a limited slip!!
Old 11-08-2006 | 09:53 PM
  #194
HiSpdPursuit's Avatar
bad idea....N/A cams are different set ups them boosted cams...
Old 11-13-2006 | 01:18 PM
  #195
XM15's Avatar
Bump. Any news?
Old 11-13-2006 | 01:20 PM
  #196
Jackalope's Avatar
Still waiting! Starting to give up hope.
Old 11-13-2006 | 03:41 PM
  #197
g5mike's Avatar
dont give up hope the machine shop will be finished up tomorro and Im gonna overnight the valves and maybe valve guides tomorro from JbP and then the shop has just got to put it back together,the shop was just being cautious to make sure it was not anything more than bent valves,once again sorry guys!
Old 11-13-2006 | 03:45 PM
  #198
Jackalope's Avatar
Ok I'll keep holding my breath but your car better break into the 14's with all this trouble!
Old 11-13-2006 | 03:52 PM
  #199
g5mike's Avatar
I have no doubt that it will,just check out the ecotec forums, they have 2.2 na there in the 14s
Old 11-13-2006 | 03:54 PM
  #200
Jackalope's Avatar
LMAO! Yeah no kidding I had my 2.2 Cavi. running 14.6 N/A all day long!
Quick Reply: JBP VVT LE5 Camshafts
