just to make sure......(intake)
Old 08-08-2009 | 11:12 PM
Cobalt08_sport's Avatar
When you take it off the air intake u just unscew underneith the engine cove and for the lil electronic thing in the side of the tubing, do u just pull that out or it there something else i gotta do??
Old 08-09-2009 | 01:08 AM
08G5GT2.4L's Avatar
To remove the stock intake you loosen the clamp on the throttle body and airbox, then remove a push pin located near the fuel rail. This removes the big plastic thing over top the TB. Then to remove the box I believe its 3 10mm nuts and it pulls out. Be CAREFUL with the MAF Sensor (electronic thingy as you put it) remove it carefully as it can be easily damaged.
Old 08-09-2009 | 10:12 PM
Originally Posted by 08g5gt2.4l
to remove the stock intake you loosen the clamp on the throttle body and airbox, then remove a push pin located near the fuel rail. This removes the big plastic thing over top the tb. Then to remove the box i believe its 3 10mm nuts and it pulls out. Be careful with the maf sensor (electronic thingy as you put it) remove it carefully as it can be easily damaged.
tb?? throttle body??
Old 08-10-2009 | 07:21 PM
08G5GT2.4L's Avatar
yes.
Old 08-10-2009 | 10:20 PM
Originally Posted by 08G5GT2.4L
yes.
how do get the clamp to come loose??
Old 08-12-2009 | 07:35 PM
tambrico's Avatar
The clamp? Are you kidding man? You just push the two ends together.
Old 08-12-2009 | 07:36 PM
tambrico's Avatar
The clamp? Are you kidding man? You just push the two ends together or unscrew it, depending on which clamp you're talking about.
Old 08-12-2009 | 09:05 PM
the one that is from the TB to to the intake... and does that go back on??
06MetallicBalt
08-17-2021 03:40 PM
dennis69
10-20-2015 04:49 PM
no_ss
10-18-2015 11:58 PM
Stuff
10-01-2015 05:47 PM
OrangeCoba
09-25-2015 06:06 PM
Quick Reply: just to make sure......(intake)
