LE5 Forged Internals and Turbo Build
Old 11-19-2018 | 11:04 PM
  #126
BKRBeez's Avatar
I THINK the brembos will fit under the stock ss/na wheels with just a 5mm spacer, but ill let someone else confirm this. I did the 5x114.3 swap on my car, basically you just need a machinist to drill 5 new holes in the hub at whatever diameter you want. 5x114.3 is the most common because of the wide variety of wheel choices available.
I do not daily drive my cobalt any more. I actually didnt drive it at all in the past year since I bought my house. Its looking like ill be able to play with it more once spring rolls around. I picked up a 2014 Mitsubishi Lancer Evolution to be my daily driver/grocery getter for here in the snow belt.
So, when you machine 5 new holes, what do they do to the original studs the wheel rested on? Are they unscrewed and put into the new holes? And aren't there structural problems w/ leaving the original holes unfilled in the hub? Doesn't drilling it out make it a bit weaker/more brittle?
Old 11-19-2018 | 11:23 PM
  #127
Yeah you just move the studs to the new holes. I havent had any problems with mine at all. Everyone does it that way.
exninja
All Cars Café
489
01-22-2022 04:14 PM
tomj77
03-23-2012 01:44 PM
Blk08coupe
04-22-2009 05:45 AM
Switt23
04-09-2008 04:41 PM
Halfcent
02-27-2006 05:52 PM
Quick Reply: LE5 Forged Internals and Turbo Build
