le5 sleeves
Old 05-17-2013 | 12:03 PM
mrbelvedere's Avatar
le5 sleeves
as of now le5 sleeves are available they are undersized and made of ductile iron and chrome moly
will be installing a set in a zzp block this weekend
Old 05-17-2013 | 12:08 PM
Staged07SS's Avatar
Administrator
Administrator
Get your car running already man
Old 05-17-2013 | 12:11 PM
LS6Rally's Avatar
Just a noob questioon i guess, why undersized?
Old 05-17-2013 | 12:20 PM
waiting on the machine work to be finished
so you can bore and hone to get the proper piston to cylinder wall clearances
Old 05-17-2013 | 12:22 PM
Staged07SS's Avatar
Administrator
Administrator
Nice!
Old 05-17-2013 | 01:24 PM
LS6Rally's Avatar
alright then, thats not what i was thinking. so its barley undersized. what about the 98MM Sleaves you had talked about in the hybrid thread?
Old 05-19-2013 | 09:01 AM
putting a le5 sleeve in a zzp girdled block
Old 05-19-2013 | 09:02 AM
those are a wet sleeve like a darton (I cant install those)and with a le5 crank that gives you a 2.7 litre
Old 05-19-2013 | 09:13 AM
LS6Rally's Avatar
Right, I remember you posting that, and I thought it would be cool. At links on wet sleeves? I just don't know much about cyl sleeves, but would like to learn!
Old 05-19-2013 | 10:50 AM
I don't have any links as they are a custom setup made to order
Old 05-20-2013 | 06:46 AM
LS6Rally's Avatar
ahh ok.
Old 05-20-2013 | 09:26 PM
noorj's Avatar
care to share the price?
Old 05-20-2013 | 09:29 PM
LS6Rally's Avatar
Holy hell, what's up Noor!
Old 05-20-2013 | 09:44 PM
OttawaMark's Avatar
Is that a gen2 girdled block?
Old 05-21-2013 | 06:20 AM
noorj's Avatar
just some summer fun
Old 05-27-2013 | 04:13 AM
OttawaMark's Avatar
Any point having these installed in a gen2 girdled block?
Old 05-28-2013 | 03:12 PM
Ceeker's Avatar
if you are making a stronger bottom end, no point to spend the $$$$ on a gen 2, gen 3 is superior in everyway
Old 05-28-2013 | 03:23 PM
EXsoccer1921's Avatar
don't mind the gen2 portion of the comment. i think what he's saying is if it's already got the guard, and that's proven itself 700+whp many times. along with ryans 900. why do the sleeves?
It's a valid question. but i think when i do my next 2.1 i'll still do these sleeves. for the cost it's more than worth it for the extra piece of mind.
Old 05-28-2013 | 07:14 PM
OttawaMark's Avatar
And I already have the gen2 zzp girdled short block, bought 3 months before they discontinued it. I would do the sleeves with new pistons, all zzp had at the time was 8.8cr and they suck fuel like greedy pigs. I'd go back to 10.4 cr and have the piston to bore clearance custom honed ...which I doubt zzp does with the stock sleeves.
Just a thought for next season.
Old 05-28-2013 | 07:31 PM
Tjolley's Avatar
Zzp never gets there bores perfictly round. They buy pistons 0.002 over size to get it close. Its kinda a halfass way to do it if u ask me.
Old 05-28-2013 | 09:08 PM
OttawaMark's Avatar
exactly, and because this is my first and last hot rod I will pay the price and finish it to proper machined tolerances.
Barring a crash I plan on having this as a toy for years to come.
Old 05-29-2013 | 06:39 AM
Tjolley's Avatar
Ya i got stuck with a block i bought from them with worn out cylinders. 1500$ down the drain
Old 05-29-2013 | 10:50 AM
Tennpenn83's Avatar
This was my block. It is a Gen 2 LE5 and I bought it in January of last year from ZZP, before they introduced the Gen 3. The cylinders were fine and round, but after about 3000 miles the compression test showed low numbers. After taking it apart, it was discovered that the piston-to-cylinder wall clearance had become excessively worn, likely due to my improper honing of the cylinders (since I am an amateur and not a pro shop). It was decided to replace the sleeves instead of pistons as the sleeves were far cheaper.
On a good note, the aftermarket sleeves from mrbelvedere, while being significantly stronger, are actually cheaper than GM OEM replacement sleeves.
Now I have an even stronger block, and peace of mind.
Old 05-30-2013 | 06:41 PM
yup
to get the clearances set up properly
yes there is a point not every one has 2k laying around for a block
even with the block guard/girdle the stock sleeve will still flex from pressure these wont and you will also have better ring control/sealing from the loss of flex
Old 05-30-2013 | 07:12 PM
Tjolley's Avatar
And from my understanding MRB's sleeves have a slightly tighter fit alowing the sleeve and block to work together to support each other.
Quick Reply: le5 sleeves
