le5 sleeves
Old 06-13-2013 | 10:36 PM
  #51
Twoozofjuice's Avatar
Originally Posted by mrbelvedere
they 2.7 is a wet sleeve and cost a lot more
no insult taken
Dumb it down a little more :/ wet sleeve like lubed? Lol what's the benefit of that
Old 06-13-2013 | 11:04 PM
  #52
mrbelvedere's Avatar
wet sleeve like a darton a darton sleeve dose not use the block for support
Old 06-13-2013 | 11:14 PM
  #53
Powell Race Parts's Avatar
Mr.B got your bolts today tank u. crazy tomorrow perhaps try and chat over w/end
thanks a lot.
Old 06-13-2013 | 11:35 PM
  #54
c130aviator's Avatar
Originally Posted by Ceeker
Oh for sure bai! No insults were intended, I respect the man for sure for his tooling skills and help for the community! was mostly brain storming. I'll shuddap if I be causin grief/de-railing his thread. Sorry boys
thanks for being cool, wish everyone had your attitude. Didnt mean to sound harsh.
Old 06-13-2013 | 11:37 PM
  #55
Instead of the sleeve pressed into the aluminum that the coolant runs around (water jacket/open deck) the entire aluminum cylinders are machined down and a full steel thick sleeve is pressed in to what is left in the bottom of the cooling area. The entire sleeve is then surrounded by water/coolant. Wet sleeve.
Old 06-13-2013 | 11:45 PM
  #56
thanks a lot.
your welcome mr powell
Old 06-13-2013 | 11:59 PM
  #57
Sweet thank you for explaining.
Cost a lot more as in just the sleeve costs more and installation stays the same or both rise? A lot more as in double or maybe more?
Old 06-14-2013 | 12:17 AM
  #58
I called Darton and a sleeved block from them was something like 1700 bucks, not including shipping the block to them and back from them. So figure 2000 ish. Better to buy a zzp girdled or gen 3. Dartons remove so much material that there isnt much for the sleeve to "grab" to and they will fail with detonation easier than a stock block with a good chromoly sleeve (mine, mrb, 100%meth, and a few others). My turbo kit came from a guy that ran his meth empty and the sleeve fell through to the crank. Boom.
Old 06-14-2013 | 04:26 AM
  #59
Cobalt_SSTuner's Avatar
Ahem....
Old 06-14-2013 | 04:55 AM
  #60
mongorat427's Avatar
The Gen 3 2.4 block can be sleeved back to stock 2.0 bore also which gives an extra thick cylinder sleeve to really put the boost to it. No girdle needed Ha Ha Im in the process of sleeveing a sleeveless 2.0 Buick turbo block with custom spun ductile iron moly alloy sleeves that are .090 thick instead of the regular .060. This meant making a sleeve without a lip.
06blackg85ss
83
01-18-2017 04:35 AM
bobbob160
09-15-2015 11:31 PM
fr33k
09-13-2007 02:37 PM
sunfirejoe
04-18-2007 02:26 PM
06noscobaltss
03-05-2007 09:37 PM
Quick Reply: le5 sleeves
