le5 strength
The LE5 uses forged rods like the LNF and LSJ engines. The pistons are probably the next weakest link in that engine. I could safely estimate that 350 number as well on a constant basis. You can get over 400 if you have a nice tune and don't burn the pistons. The Hahn numbers are solid. They were actually trying to break the engine to see how far their turbo kit could go and were not able to break anything.
SEARCH i have posted this info many times as well as elecblue.....trust me the engine will handle approaching the lines of 350-400 before it goes...some say it isnt but its designed for power...after all it was designed in light of the older saab turbo motors
would you be able to send me a link to where you discussed this
info posted by my bud....thanks elec! this should hold you over...just pick whatever motor you fancy and have at it:
https://www.cobaltss.net/forums/general-cobalt-68/info-all-balts-engine-internals-tranny-118908/
I hear the weakest part of the manual transmission is the clutch.. replace that and you help your transmission problems by quite a bit.. its just what I hear though, I have no real proof to support that.
thats a proven fact with any transmission and the addition of power past its original intent
