Lets discuss a 2.4 NA Build
#77
Methyl Alcohol
I've been kicking around the idea of doing an NA build for my 2.4, and would like some specific suggestions on how to reach my goal.
Goal: 220 WHP
Current Mods:
ZZP Shorty Header
Monza 2.5" Catback
Injen CAI
Custom Tune
(This is an NA discussion, I don't want to hear about Nitrous, or Forced Induction)
Goal: 220 WHP
Current Mods:
ZZP Shorty Header
Monza 2.5" Catback
Injen CAI
Custom Tune
Changing to cams with higher lifts MAY cause piston contact with the valves under some phase conditions... costly. A regrind to achieve faster open / close rates should also include valve spring upgrades too. Only the GM LNF exhaust cam swaps into a LE5, all other current ECOTEC cams require changing from VVT.
Take a look at the new build book and the Rousch Marine racing engine for ideas.
Good luck!
#79
for the how to. Make sure you get the entire book ( http://tunersource.gmblogs.com/Racer...mplete-web.pdf) as you'll need to be ready for a complete engine removal and disassembly, a bore out, liner insert, a stroker kit, reassembly, etc. ... Lots of time and money!!
#80
funny cuz i was tossing this idea around the other day.. lol
my ideas were to do a port match to the head 3 angle valve job bump the rev limiter to 7.5K or so and get every bolt on possible with a good tune.. also cams but then i realized it's pointless considering eventually I want to still go blown.. so unless there's a good cam setup that'll work for na as well as sc'd and will be worth it for both.. or even one that'll work for being blown well and work ok for na..
cams are totally way above my head lol
judging from redfocz/s dyno numbers some minor port/ polishing and a higher rev limiter should get you to 200 whp..
witt do you know of any place that would be good to go in our area (tri state area) for port and polish as well as valve job ?
and car the stock valves really not get to a 7K rev?
#82
#83
Yeah I am curious about the head itself and what gains can be made from a good port and polish? I mean are the heads pretty good from the factory or could they really come alive with a little work?
#84
i dunno about the 2.4's
supposedly the exhaust ports on the 2.0 head are only big enough to fit a thumb in
#85
I am pretty sure the head is for the most part different, but any better IDK?
Does anyone have pictures of the head removed?
#86
mvp might.. he did a 2.0 2.4 hybrid ecotec but i dunno which part is which but i do know he made 260 whp on 10 psi on a stock pulley
#88
to blueprint and balance a rotating assy. your looking at prolly a whole days work and whatever theyre labor rate is. bumping the comp to 11:1, and cams.
if youre gonna port and polish you should really know what your doing. if you open them up to much you will lose air flow (CFM) which will then cause a power loss. if your gonna bring it somewhere make sure they know what theyre doing.
#89
#91
my ideas were to do a port match to the head 3 angle valve job bump the rev limiter to 7.5K or so and get every bolt on possible with a good tune.. also cams but then i realized it's pointless considering eventually I want to still go blown.. so unless there's a good cam setup that'll work for na as well as sc'd and will be worth it for both.. or even one that'll work for beblown well and work ok for naing ..
#92
before we go too far with this, i would like to bring up a point on the 5 speed tranny in these 2.4 cars since i hasnt been addressed yet in this topic.
The 5 speed in the 2.4L is only rated up to 170ft lbs of torque from the factory, there is a member on here by the name of Beck with a supercharched 2.4 that has gone through 2 F23 trannies since swapping in the supercharger, his car producing more then 170 lb lbs of torque and he has killed 2 transmissions because of it.
If you are going for 220 whp, your going to also need to invest into transmission upgrades also or you wont have much fun with it.
Heres a thread with some info on the transmissions:
https://www.cobaltss.net/forums/show...ansmission+170
#93
#94
#96
Meaning not beating the **** out of them grinding sincros and things of that nature. Plus your putting such a large stero type on the transmissing based off of a single person. NOw if 10-15 other people where going through transmission it might have some weight behind that statement. But seeing the Cavi and Sunfire guys running alot more HP and TQ compard to Beck for alot loger of a time frame.
Just my two peso's
Just my two peso's
#97
P+p
BTW, Crower cams make exceptional camshafts. Call them and you often times will be directed to an expert on the matter, rather than just someone who reads off a computer screen to tell you which part number is best. They assisted me in the custom design of my cam in my Chevelle, and I have a well-mannered streetable car that still pulls past 7100 RPM with a "worked" dual plane manifold and a hydraulic-roller cam. If you chose to go with them, you will not be disappointed.
MLRTYME
08 Sport Coupe
www.wannaberacing.com
#100
