Lightweight/Under drive Crank Pulley?
Old 01-20-2012 | 03:21 PM
LE5's Avatar
LE5
So around the internet I found a Light Weight Crank Pulley for the 2.4 and an even lighter Under Drive pulley. I'm wondering if those are even worth it.
I thought having some mass on the crank could improve torque, But I guess having a lighter pulley could help the motor rev up faster.
What do you all think. Worth the money or waste of time?
Old 01-20-2012 | 03:31 PM
OttawaMark's Avatar
NO!
READ: ATI - Crankshaft Dampers 101
/END
Old 01-20-2012 | 03:34 PM
chevygirl2006's Avatar
People have had alot of problems with those.
Old 01-20-2012 | 03:38 PM
OttawaMark's Avatar
ATI - The Dangers of Power Pulleys & Understanding the Harmonic Damper
Old 01-20-2012 | 03:53 PM
nhanson's Avatar
Nope
Old 01-20-2012 | 05:17 PM
LE5's Avatar
LE5
ok great, thanks for the info. I didn't know the crank pulley on the LE5 was a damper too, To me it just looked like a plain pulley. But Either way I won't be wasting the money on it.
Thanks again!
on another note I saw that there was also lightweight pulleys for the alternator. I would assume that those are also pointless.
My guess is the only pulley I would ever want to replace to gain performance is the pulley on the blower for a supercharged motor...
Old 01-21-2012 | 01:48 AM
OttawaMark's Avatar
Yep, saving a few ounces off some pulleys when you've got pounds and pounds on the crank between the damper and the flywheel/flexplate is pointless in normal driving conditions.
Old 01-21-2012 | 09:42 AM
LE5's Avatar
LE5
Good point. Thanks again!
Old 01-21-2012 | 11:12 AM
Mindrot's Avatar
Don't use it.
Old 01-21-2012 | 02:05 PM
LE5's Avatar
LE5
Don't plan to, thanks to you guys!
10-20-2015 09:56 PM
SSLOW06
10-01-2015 07:21 PM
Stuff
10-01-2015 05:47 PM
patooyee
10-01-2015 01:07 PM
cw383
09-30-2015 12:41 AM
Quick Reply: Lightweight/Under drive Crank Pulley?
