LNF cams
LNF cams
I found a post I thought was interesting and might help the people who are running turbo setups on their LE5.
If the cams are interchangeable, this might be an alternative from doing a custom regrind. Also does this mean that any aftermarket cams for the LNF will work too?
Thoughts on this?
LSJ and L61 cams are interchangeable up until 2006.
The only difference is the timing;
'06 L61 116 Intake, -103 Exhaust
'06 LSJ 100 Intake, -115 Exhaust
2007 L61 intake cams are not interchangeable with any other ecotec cams.
2007 L61 exhaust cams are interchangeable backwards to a previous model year L61 or LSJ
LNF and LE5 exhaust cams are interchangeable with each other but not with any other ecotec cams.
All LSJ cams are interchangeable.
Thanks,
JBP
Thanks,
JBP
Thoughts on this?
The intake cam on the LE5 is more agressive then the LNF intake cam, but is not swappable.
The exhaust cam on the LNF is more aggressive then the LE5 exhaust cam and IS swappable.
So the LE5 guys can use the LE5 intake cam with the exhaust LNF cam and have most aggressive factory cam setup possible, but this will only work in the LE5.
