Making le5 lnf
Making le5 lnf
Hoping someone could help me out. I was looking around for a 2.0 block and noticed 2.4 block seemed to be easier to get and way cheaper. Does anyone know for sure if a lnf crank would fit inside a le5? I was thinking of putting everything lnf inside the le5 block. Lnf crank, rods and pistons. I would just get 88mm lnf pistons (wiseco). I assumed the blocks would be similar and you would be able to bolt this all up? Then I would put a lnf head on also.
I would use both aftermarket pistons and rods. 88mm wiseco and aftermarket forged lnf lsj rods (145 or 145.5mm). I think I saw someone saying it would probably work. I think they said it would end up with a 2.1l displacement. I couldn’t find much info on the build. It was on kappa forum I found information.
This is a 2.1L conversion. I've seen a couple LSJ's do it, but never an LNF. ZZP makes the pistons for an LSJ to do the conversion, but again, I never saw anything about them doing it for the LNF's.
Custom pistons should be all that you need. Unsure if you'll need the Crank Position Sensor spacer, or if that is an issue specific to LSJ's.
Also, all Ecotec blocks are essentially the same in their fit, form, function. There are a few revisions/differences here and there, but they were designed to be like legos. I've used an LNF block with LSJ internals and head.
If you had bought a Gen 3 2.4L block, you'd already have a girdled deck.
I thought the same thing initially too, but they are sleeved. Unlike previous Gens, the block is actually cast around the sleeves, so the deck is all aluminum and the steel sleeves are underneath that.
[QUOTE=USMCFieldMP;7754714]If you had bought a Gen 3 2.4L block, you'd already have a girdled deck.
Block should be a gen 3, but I’m not certain. Block title said it was for years 2010-2017. https://www.ebay.com/itm/165015416535 That’s what I got. The engine and crank are suppose to be here tomorrow, but I’ll probably have to wait at least 6 weeks to do the build cause I can’t find rods.
