Maybe going to start...
Old 09-04-2008 | 07:03 PM
cakeeater's Avatar
building a custom turbo setup can be easier than a custom blower setup depending on the application and what kind of blower you use.
Old 09-04-2008 | 09:10 PM
glen229's Avatar
Originally Posted by celicacobalt
i went turbo and would do it again if that means anything.
how are you making 350 tourqe and 260 hp?
nice car tho
Old 09-04-2008 | 09:40 PM
thekingsSS's Avatar
nice car tho
He makes 358 lbft at about 3800 RPMs...
261=(358*3828.972067)/5252
HP=(TQ*RPM)/5252
Old 09-04-2008 | 10:39 PM
elecblue06's Avatar
well hello there.. i actually happen to be in the middle of a procharger build for my 2.4 ion myself.. custom ish kit with the help of AAS tuning and SMP I'd recomend you wait till i'm done before you do anything .. i did it so i can be different i'm not looking for a ***** to the wall superfast car..
it's really not that hard..
you need a c-1 reverse rotation blower, piping, bypass of bov, bigger injectors, bracket, smooth alternator pulley, 3.2 pulley, some misc bolts and brackets, front mount, new belt, sc oil, gauge pod, wideband, interceptor, and boost gauge, and most of all someone with hptuners or efi live that will tune you
now it's really not THAT bad to do this project.. however before seeing numbers on a 2.4 i'd advise you staying away
on the 3.2 pulley i'm going to be running to start we've projected about a 65-70% increase in hp so i should be sitting around 240+ whp on about 10 psi.. i'm hoping to finish it up within the month
Old 09-04-2008 | 10:49 PM
glen229's Avatar
HP=(TQ*RPM)/5252
i was never good at math
Old 09-05-2008 | 03:39 AM
maverick0716's Avatar
If you get an actual turbo kit from Hahn, it's basically just a bolt in kit as far as I know. They give you the tune, new injectors and everything. If you get the Garrett kit and purchase 60# injectors plus a custom tune it's even better, apparently.
Old 09-05-2008 | 03:41 AM
Bades's Avatar
subscribing... and like ^^^^^^ sed just turbo it.... unless u want to be different
100% METH
Tuning
10-22-2013 09:00 AM
Nfamous60
48
06-02-2013 06:34 PM
Quick Reply: Maybe going to start...
