Meth Injection on a N/A car
Now before you go tearing into me I'm just putting this up because SOME N/A cars can see a benefit to adding meth injection. Also there is yet to be a thread to actually answer this question or throw up dyno #'s. Alright my question is has anyone seen hp gains from adding a meth kit to an N/A cobalt, specifically a 2.4. Here are some of the things an N/A car can gain from meth.
Benefits of Water Alcohol/Methanol Injection on NA application:
Lower air charge temperatures by 30-40 degree's
Reduces cylinder temperatures by 200+ degrees
Increase your 87-93 pump gas by 10-15+ points
Allows the use of lower grades fuels
Allows you to safely run more timing
Cools and protects the tops of your pistons
Longer more stable combustion expansion and progression
Removes carbon build up from combustion chambers, pistons and valves
Reduces & helps eliminate damaging engine detonation & pre-ignition
No need for expensive racing fuel or additives
Thanks for any feedback.
I'd love to! Idk I've thought alot about nitrous, but at the end of the day I wouldn't want to fill bottles. It's $62.50 for a 10lb bottle here. I'd want to use it all the time. For me I'd be a lot happier and feel like my money was better spent if I turbocharged. That isn't gonna happen cause if I'm going I'm going all the way with Stage 3 zzp. Too bad I'm a broke ass college kid. RPI = -$200,000ish
How much more timing could you really add? I mean I have a 2.4 here in tx on 23 degrees at 12.3 afr on 93. So not sure if more timing would really help out any. Nitrous would be a much better hp gain hell 50 shot would do wonders.
don't do that. depending on who tuned you, you may have a high octane timing in your low octane table as well, so even if.
There is a high and low octane table for the cars. There are few factors that make the car select which table it needs to use. When I get to my laptop I will post up some pics of what I am talking about.
Macgyver2484
09-02-2015 05:44 PM
