Miss-fires?
Miss-fires?
So I installed my full exhaust today. (vibrant header with hi-flow cat, and ark dt-s exhaust) I don't have any kind of heat shield anymore factory one doesn't work but I am getting some miss-fires. It's not jerking or anything and when it does happen it is only 1 or 2 and then they are gone. Its across all cyclinders but not every time. My only guess it the extra heat getting to the ignition wires. any clue to why I am getting then and how to fix it?
Never threw a misfire code until a few days after my mid length header/dp went on. Cleared it, havent seen it again. But, my interceptor still shows a misfire here and there, 2-6 usually, from cylinder 3. I swapped 2 and 3 coil packs, but still only showed misfires on 3. Even changed injectors as I went bigger, still #3 here and there. Theres a few threads around about random misfires and seems pretty common. And my LTFT's are in the negatives just about always.
yeah I haven't seen anything higher then 2 on each cylinder. but I have gotten 2 cylinders mis-firing at the same time.
