motor cutting out
motor cutting out
i installed a injen intake i got for free that came off a 07 2.2 ion. and a tsudo exhaust behind stock cat. i did put my stock mass air flow sensor in and cleaned it. check engine light is on with a code fuel "to rich" wich doesnt bother me but when i floor it in 2nd around 3k-4500k rpm the motor cuts out for a split second. i would like that fixed. is there a aftermarket mass air sensor that will compensate for this cutting out my motor doing and has anyone possibly had this same problem?
I had it with my k&n for awhile it would be weird and cut when it would shift from wot from 1st to 2nd but I'm an auto I would check all your connections make sure they are tight and if you used the crank case vent. Tube make sure that is on very tight that's where my problem was
ThoR294
10-04-2015 08:44 PM
