Mpg?
ive found my dic to be quite accurate i do the math and compare maybe once every 2 or 3 months. i usually get around 25-28 city and around 31-35 highway. honestly i thought i drove excessivly but you guys put me to shame. oh and i did see 40+ on a trip from Biloxi MS to Jacksonville AR doing 80+ the whole time. made it on a single tank and its a little over 400 miles.
i got 38.9 mpg at about 50 mph average today on the way to work. did nothing differently than normal other than let off the gas when a light turned red, and coast to the light instead of keep accelerating then hit the brakes. i figured it would be slightly better mileage, but ****, almost 40mpg especially considering it was stop and go is damn impressive.
Original Hayden Fanatic
th real way to get your MPG, do the math at the fill-up... miles driven divided by gallons of gas, boom, done.... that litte electronic thing is off by sometimes around half a gallon to a gallon anyways.............. anyhow, anywhere between 20-24 city and anywhere between 30-34 highway
do you know precisely how many gallons, down the the ounce were put in the car? probably not. that leaves room for error. there's your half a gallon also, suppose they put a tad more than the 13 gallon fillup, or a tad less. unless you are taking off your gas tank, dumping it out, and measuring, there's no way it's 100% accurate every single time. close, yes, but not 100%
Resetting the mpg meter, and doing my own math for nearly a year now, I found the meter is usually reading 2 mpg more than my own math at the pump. (27 on math, 29 on meter) Secondly, the whole reason this started was b/c of the Mythbusters where they confirmed the myth that you get better milage with the windows down than the a/c on.(bearing in mind it was two Explorers they did it in)
The a/c in my driving takes about 3 mpg off of the life of the tank. Even at speeds over 75, just cracking the windows open is better. All the way open though, and there's too much drag to tell the difference from what I saw. Also ticked at yahoo.com b/c they said differently on the front page today, debunking my research. I'd think they used a V8 when saying that, but then that contradicts what Mythbusters did.
#40
^agree.....your mileage would be different from mine....i deliver zza's so im constantly starting and stoping and i live in a decent size city so their are tons of lights and stop signs etc etc.....i get about 19.5 when im babying it
#44
The most accurate way to get the mileage over the entire tank is to calculate it based on the fuel you just replaced. If you put in 12 gallons to fill it up and you drove 300 miles on the 12 gallons you just replaced then you got exactly 25mpg. A gas pump kicks off when it detects back pressure in the filler neck. As long as the pump is properly maintained they should all kick off at about the same point (or use the same pump each time if you wish). If it shuts off and there are a few ounces different it won't make a MEASURABLE difference in MPG. Who cares if there is a .001 change in mpg because of the pump not putting in that last few oz the last one did? So yes it is very accurate to the whole tank method.
Now as far as the mileage my 2.4 gets. Usualy 25mpg with about 90% city driving. The worst I got was around 22 in the dead of winter for all my city driving.
I just did a trip to Chicago and we did 32.5mpg on my best tank. I was running 71 mph on cruise pretty much the entire way. On this trip the DIC was pretty much spot on since there was no stopping.
You guys must really get on it alot to get such low numbers
#45
I constantly start and stop with tons of lights and stop signs. And let me tell you... Staten Island has a serious serious traffic problem.... it's NOT a fun place to drive as you might think it is. It's NOT uncrowded!
Last edited by chevy cobalt 08; 05-24-2008 at 02:44 AM. Reason: Automerged Doublepost
#48
But wouldn't the results be the same? You figure the zeros when you are sitting still would bring the average down but isn't it for a good reason because you aren't going anywhere? Or if you did it by calculating it yourself and just sat there idling for a while, this would be reflected in your results too anyway wouldn't it?
The DIC is never going to be closer than "doing the math". The DIC is an average that is easily thrown off. If you sit there and don't move for a minute it puts 0mpg into the average. If you know anything about averages when 0 is added in even for a short time it really throws the number off and it will be lower than it should be. I find that the dic is a decent guide but it will always read a bit low due to this factor.
