... My Build... Muhahahahahha
Old 01-09-2012 | 03:48 PM
  #401
elecblue06's Avatar
wewt, cams finally came in from comp/ zzp
Old 02-21-2012 | 11:28 PM
  #402
elecblue06's Avatar
obligatory misc update.. bought projectors TL-r (no not TL projectors), shrouds, ccfl halos, 6000k d2s bulbs, 55w ballasts, amp to d2s harness, and mounting hardware, as well as new electronic boost controller. Next I'm buying 80s so I can kick this ****** up into big time cams still need to be put in.. and might be getting neutral balance shafts to put in when I get cams done.
also might be porting the exhaust ports (gasket matching / smoothing) one of the spare heads I have
all in all car is getting closer and closer to nothing left to do
Old 02-22-2012 | 10:45 AM
  #403
REDFOCZ's Avatar
Taking you a while to do this Kyle, but you have gotten a few things done since last time I looked into this
Old 02-22-2012 | 10:53 AM
  #404
elecblue06's Avatar
unfortunately I've been laid off for a good portion of the last 2 years so I have a bunch of **** that i've either wanted to buy or I've bought and I'm waiting to install
Old 02-22-2012 | 11:10 AM
  #405
hhrfreek's Avatar
Are you running e85? 60s should be fine on gas.
I am regretting not doing neutral shafts and the ATI balancer when I built my motor a few months ago. I am likely doing it this summer, but I am going to see what I make on the dyno this time around. If my power is still falling off then I won't do the shafts.
I ported my head as well. Make sure to go nuts on the exhaust side. You can really open them up. Also a lot can be done around the throat/valve seats on both in/ex. Hoping that along with the full 3/2.5" exhaust will keep the hp climbing.
Old 02-22-2012 | 11:29 AM
  #406
elecblue06's Avatar
yea I'm running e85 currently unfortunately right now the cars become my dd and there aren't a whole lot of stations around, more then most people though. I was going to do neutral shafts but then I had to buy a new block when I built my engine so i decided against it ... the ATI balancer i don't really care about.. like you said i want to dyno it to see what my power is doing if it's tanking then I wont be revving it to 8k much anyway
Old 02-22-2012 | 12:21 PM
  #407
ebristol's Avatar
Do you have pics of your port?
Old 02-22-2012 | 01:27 PM
  #408
REDFOCZ's Avatar
Sucks being laid off, I just got let go from my job aswell
but seeing what you have done makes me miss my Ion
Good luck with the build
Old 02-22-2012 | 02:05 PM
  #409
elecblue06's Avatar
damn man that sucks hard core, I haven't talked to you in a while/ haven't seen you online either .. hope things get better for you
Old 02-22-2012 | 03:18 PM
  #410
REDFOCZ's Avatar
Thanks man, yeah since getting rid of the Ion, and ranger I fell off the GM seen. I am more active in the focus group again
Old 03-11-2012 | 10:36 PM
  #411
elecblue06's Avatar
well the time has come i have ALOT of things to install this coming weekend...
PRS rotated mounts
canuck springs
Fx-r 3.0 (TL-r) projectors with 55w hids
80s
new tune
re hook up my sun roof lol
MAYBE
driver side axle
FE5 endlinks
FE5 control arms
custom fuel rail cover
sub install on my DD ( i know that has nothing to do with this thread but still)
I was thinking about doing cams but I dont forsee that happening with the rest of the **** i'm doing
Old 03-11-2012 | 10:48 PM
  #412
09CobaltSS1's Avatar
still slow!
Old 03-11-2012 | 10:50 PM
  #413
elecblue06's Avatar
Originally Posted by 09CobaltSS1
still slow!
Y U STOP TALKIN ON AIM!?
Old 03-11-2012 | 11:04 PM
  #414
The wife was giving me ****!! lol
I'm good now though
Old 03-12-2012 | 01:08 PM
  #415
ebristol's Avatar
How did the install go?
Old 03-12-2012 | 01:50 PM
  #416
elecblue06's Avatar
install of ? everything i listed will be installed this coming friday-tuesday. projectors 80s springs and finish boost controller will be done on friday ( well i'll be starting the projectors)
Old 03-12-2012 | 02:43 PM
  #417
ebristol's Avatar
I see.
Old 03-13-2012 | 02:25 PM
  #418
Zdeuce4's Avatar
this car fast yet?
Old 03-13-2012 | 02:27 PM
  #419
elecblue06's Avatar
Originally Posted by Zdeuce4
this car fast yet?
meh fast is relative
Old 03-13-2012 | 02:28 PM
  #420
Zdeuce4's Avatar
lmao
troof
Old 03-15-2012 | 11:23 PM
  #421
elecblue06's Avatar
80s in
boost controller gets fixed tomorrow am
projectors get started in the pm
debating on if i should cut the muffler off ... take out the auger insert I have in there and get the muffler welded back on .. what do you guys think
Old 03-16-2012 | 10:06 AM
  #422
ebristol's Avatar
The auger should not be affecting flow too much, right? I would leave it a lone.
Old 03-16-2012 | 10:35 AM
  #423
elecblue06's Avatar
air flow now.. sound yes it's in the center of a magnaflow straight through
Old 09-07-2012 | 12:34 PM
  #424
ebristol's Avatar
Bump!
Old 09-08-2012 | 02:34 AM
  #425
elecblue06's Avatar
haha obviously put down 324 whp and 315 wtrq on 14 psi .. with a fucked up ecm..
sending turbo to be upgraded by bnr maybe finally doing my head and seeing how engine is looking
trying to get a dd though
looking at getting a veloster turbo inj a month or less
Quick Reply: ... My Build... Muhahahahahha
