... My Build... Muhahahahahha
Old 09-10-2012 | 09:49 PM
  #426
ebristol's Avatar
Still on the stock short block right?
Old 09-16-2012 | 10:05 PM
  #427
elecblue06's Avatar
nope built bottom end
Old 02-27-2013 | 05:51 PM
  #428
elecblue06's Avatar
woh long time no see thread... hopefully be doing some updates to this soon... 400 whp here we come
Old 03-03-2013 | 08:34 PM
  #429
Zdeuce4's Avatar
still goin for 400?lol
Old 03-03-2013 | 10:46 PM
  #430
GoodLuckBro's Avatar
What'd this thing handle on stock engine?
Old 03-04-2013 | 01:29 AM
  #431
elecblue06's Avatar
haven't changed anything since last time.. i should be damn close to it now .. i'm going for 450 on the dyno but wont drive it with that on the street lol
the stock engine took well over 360 wtrq and 260 whp.. i dynoed that on 15 psi falling to 7 psi by redline on the stock k04.. when it blew up apparently I was seeing 15 psi at redline lol
Old 03-04-2013 | 01:34 AM
  #432
Pitbull2o08's Avatar
What exactly broke? Rod? wall?
Old 03-04-2013 | 02:54 AM
  #433
Just figured I'd ask someone who's been through it. I haven't been able to find a definite answer. I just upgraded to a stage 2 zzp kit on my '07 le5 and I heard it can handle 300whp and 10-12psi safely but I've also heard 350whp and no more or that 12 psi is pushing it.
Old 03-05-2013 | 11:16 PM
  #434
Zdeuce4's Avatar
forgot you had switched to the snail
Old 03-06-2013 | 01:42 AM
  #435
elecblue06's Avatar
piston had a chunk out of it lol which would be from excessive heat and low end stress
as far as what it can handle.. whp isn't the best way to look at it .. it's heat cylinder pressure and low end trq that will kill your motor prematurely.. and your tune..
as far as only 12 psi.. i had more then that on the procharger and k04... procharger should've been putting down around 320 whp but i never dynoed it properly on 13 psi (highest I got was on 8.5 psi(13 psi pulley but i was having tensioner issues) and that put down 250 whp and 240 wtrq (which was 40 wtrq more then i dynoed it on my 7 psi pulley) and like i said with the k04
Size:  74.6 KB k04 dyno
Size:  42.3 KB chunk out of piston..(put a nick in the cylinder wall as well.........rawr) I was planning on building the engine anyway so i could feel comfortable with the BNR on the car.. i had 92k on the stock engine lol and 30k of boost
keep in mind on the procharger I was running the car to 7400 on an almost daily basis, on completely stock engine, same thing with the k04
Old 05-02-2013 | 07:58 PM
  #436
06_ion2's Avatar
Damn so this still runs?
Anyone tune us besides Vince? I really want to put a new trans in my car but I'm losing out on power with his tunes.
Old 05-05-2013 | 12:23 AM
  #437
elecblue06's Avatar
you gotta get your **** dialed in last you told me you were running mid to high 10s aft.. no one else can do 06 2.2 ions that i'm aware of ..
and yes it still runs getting a brembo swap right now lol.. next is the ported head and cams and hopefully bigger turbo lol 450 whp here we come
Old 05-10-2013 | 02:56 PM
  #438
mmcgee123's Avatar
Good luck with those stock sleeves
Old 08-01-2013 | 11:59 PM
  #439
ebristol's Avatar
Bump.
Old 08-02-2013 | 08:54 AM
  #440
noorj's Avatar
interested in this also, would like to know how far I can push my motor before she pops
Old 08-02-2013 | 07:26 PM
  #441
elecblue06's Avatar
still on stock sleeves....
getting cams, ported head, and moar boost crammed into her soon.... will be easily over 400 whp
Old 08-02-2013 | 09:42 PM
  #442
noorj's Avatar
damn, how much boost is that? thats some awesome numbers man good job. is this built motor +bnr 2871
Old 08-02-2013 | 10:49 PM
  #443
elecblue06's Avatar
it's a spike of 19 but then only holding 15-16 (hense the huge torque numbers but mediocre HP number)
but yes rods, pistons, valve springs.. and bnr
Old 08-03-2013 | 02:32 AM
  #444
noorj's Avatar
that's alot of boost for stock sleeves, and a **** ton of torque lol. makes me feel better about my motor
Old 08-03-2013 | 06:33 AM
  #445
06blackg85ss's Avatar
stock sleeves can hold quite a bit if properly tuned (and don't go apeshit on the boost controller like I did 34psi was goodnight lol) my buddies car was making over 500whp on the stock bottom end with 29psi e85 and a 6262. My motor lasted for years at 400-450whp completely stock at 25 ish psi.
Old 08-03-2013 | 10:40 AM
  #446
noorj's Avatar
I do think that the LE5 sleeves are considerably weaker than LSJ sleeves though
Old 08-03-2013 | 11:55 AM
  #447
probably, but I"ve seen over 400whp on stock le5's also before.
Old 08-03-2013 | 03:09 PM
  #448
elecblue06's Avatar
yea the top guy for le5's is running stock block .. long as you have a good tune you shouldnt have a problem with sleeves
Old 08-03-2013 | 05:59 PM
  #449
noorj's Avatar
I'm not trying to argue or anything I'm just wondering, but sleeve failures are pretty obviously too high of combustion chamber pressure related failures. So they only way of it being in the tune would be too aggressive ignition timing which is usually what the customer asks for. Even having fueling off wouldn't effect cylinder pressure, if anything a little lean up top would bump egts but decrease cyl pressure from slower flame propagation. So how else would the tune make you pop sleeves?
400whp is pretty crazy, I wonder how long they've driven the car at that power level for. Do you daily your car at that boost elecblue? Really makes me feel good about my motor lol
Old 08-03-2013 | 06:23 PM
  #450
elecblue06's Avatar
i used to daily my car I dont any more .. but it is always at the boost it made those numbers at though and it regularly sees wot
as far as sleeves... put it this way... lsj's were having issues blowing motors and killing sleeves around 300 when they first came out .... now they're pumping over 400 on fully stock motors
Quick Reply: ... My Build... Muhahahahahha
