My experience installing zzp stage 3 turbo kit.
Old 07-12-2013 | 10:21 PM
  #101
noorj's Avatar
GUYS I got a question!!!
Do you have to remove the coolant crossover pipe to get to the oil feed fitting?
If so is it just drain coolant, unbolt pipe housing, done?
THANKS
Old 07-13-2013 | 12:01 AM
  #102
Cherry GT's Avatar
NO
I did not.
Old 07-13-2013 | 12:10 AM
  #103
Cherry GT's Avatar
and I believe it is a 6mm allen with sealer on it,
don't strip out the allen !
Old 07-13-2013 | 10:28 AM
  #104
noorj's Avatar
another question
you guys running aftermarket intake manifolds, what gasket do you use?
Old 07-13-2013 | 12:08 PM
  #105
c130aviator's Avatar
stock with a coat of copper gasket spray.
Old 07-13-2013 | 04:56 PM
  #106
noorj's Avatar
Like the copper rtv used on exhaust manifold gaskets? Got it
Old 07-13-2013 | 05:01 PM
  #107
chevygirl2006's Avatar
Count down is 4 months guys!
Old 07-13-2013 | 05:30 PM
  #108
Cherry GT's Avatar
NO
he said SPRAY COPPER COAT !
Not copper rtv.
Old 07-13-2013 | 05:47 PM
  #109
noorj's Avatar
ohhhh never heard of that before
Old 07-13-2013 | 06:02 PM
  #110
not my video but this stuff.
Old 07-13-2013 | 07:17 PM
  #111
noorj's Avatar
do you just spray if over your stock gasket?
Old 07-13-2013 | 07:55 PM
  #112
Cherry GT's Avatar
it was originally developed to seal imperfections in head gasket surfaces,
great stuff !
Old 07-19-2013 | 09:26 AM
  #113
noorj's Avatar
bringing this thread back up!
What do you boosted guys run in your tune in terms of boost/afr/timing?
Right now I'm at .787 PE ratio on 8psi with timing ramped from 8-13* up top, nice and conservative until I fully dial in the maf then push it some more.
Old 07-19-2013 | 03:55 PM
  #114
Cherry GT's Avatar
11psi, 11.5-11.8 to 1, 14
Old 07-19-2013 | 04:32 PM
  #115
noorj's Avatar
you think 11psi is safe, long term?
not insinuating anything I just don't really know what I should run for the best mix of fun and longevity
Old 07-19-2013 | 08:24 PM
  #116
Cherry GT's Avatar
I'm not boosting every day, so heck yeah !
I've been running 11 psi for a bit over 3 years and 20,000 miles on bad tunes (lol),
been to the drag strip many times and my only issues were turbo journal bearing
oiling problems and I may have taken some advice from Bullseye that I should have
walked away from.
forgot to add.....
that 11 psi is with a s256et, I don't know your turbo
so psi could be different.
Old 07-20-2013 | 12:31 PM
  #117
noorj's Avatar
It would definitely be different power, but boost is pretty indicative of cylinder pressure no matter what turbo. And with our thin sleeves I'm trying keep that down as much as possible. Thanks for the info though, I have a feeling I'm going to be boosting pretty much daily so I'll be tuning at 8 psi and go from there.
Sean Cummings
01-08-2020 10:17 AM
deviance
11-24-2015 05:51 PM
Tdubbs
10-13-2015 02:31 PM
Sean Cummings
09-11-2015 09:35 PM
CobaltSS 16
09-06-2015 02:04 PM
Quick Reply: My experience installing zzp stage 3 turbo kit.
