New Cat
Old 11-23-2007 | 08:32 PM
SSam2.4's Avatar
New Cat
Had my CA header and XTC dp on for 120 miles . I was wondering how long of a break in period should I give before I drive it normally (4000 + rpm) ? Thanks for any responses .
Old 11-23-2007 | 08:41 PM
matt_SS_205's Avatar
idk what it is actually supposed to be, but i took it easy on mine for 250 miles
Old 11-23-2007 | 08:43 PM
D4u2s0t's Avatar
500 miles is the standard break in for a cat.
Old 11-23-2007 | 08:46 PM
well i've put a couple thousand on mine since and no trouble out of it, i asked around on here, some say there is no break in some say 250, some say 500 so idk i went with 250 since it was a happy medium
Old 11-23-2007 | 08:53 PM
iLLmaTic3s's Avatar
yeah 500miles is normal break in...dont go that fast..it will easily clog the cat
Old 11-23-2007 | 09:06 PM
SSam2.4's Avatar
OK so 300+ miles . When you say don't drive it fast do you also mean don't rev it high ?
Old 11-23-2007 | 09:07 PM
iLLmaTic3s's Avatar
dont go WOT...or dont even try to rev it high..
Old 11-23-2007 | 09:10 PM
SSam2.4's Avatar
What rpm is reving high ?
Old 11-23-2007 | 09:19 PM
D4u2s0t's Avatar
play it safe and wait the 500. look up how many "my cat is clogged, what a piece of **** downpipe xxxxxx sells" threads. or, look up all the cel's from bad cats. it's not worth it over 250 miles. i would just take the time and make sure you do it right.
Old 11-24-2007 | 02:47 PM
SSam2.4's Avatar
Thanks for the info 500 it is and I'll drive like I own it instead of stoled it . Thanks again .
Old 11-24-2007 | 03:23 PM
D4u2s0t's Avatar
it's a good idea. there's people posting cat problems all the time. most likely from not being broken in properly. you may not notice the problems for a while, so people don't think it had anythign to do with break in.
01-12-2016 12:01 AM
nathan112i
09-30-2015 07:12 PM
goaliemo
09-28-2015 01:37 PM
09-27-2015 08:53 PM
09-26-2015 06:44 PM
Quick Reply: New Cat
