New injectors and tune!
Old 02-02-2007 | 01:49 PM
  #51
LewiSS's Avatar
Originally Posted by Psykostevo
With the Redline set so high, the IDC was up to 98% in 3rd gear, and we started seeing knock as soon as the IDC went above 90-92%. Only 2.8* of knock, but still not a good thing. Luckily all the knock went away with the new injectors, because 1-2 gear was about 72% max IDC, and 3rd Maxed at 76% with 3 people in the car. Since there was no knock, we added some more timing, and drove it without any further knock.
My next goal is to reprogram the VVT, but as you can guess, that's not an easy task.
Very interesting. Did you instrument it stock to see what the IDC is like with no changes? I believe Chevy used injectors that are right at the limit even stock - not sure why unless it helped them pass emissions.
It might be worth a trip out your way to tune mine once the weather starts to get better.
As for the VVT tuning, early systems like the 2.0 Alfa Romeo switched simply based on RPM. Does it appear that the computer for ours is more complex, sensing engine load, throttle position, etc? I'm not sure how much gain there would be in switching the cam timing earlier or later. However, I learned from tuning the Alfas that I definitely like VVT - great idle, good low load crusing, with much better cam timing once it switches.
Old 02-02-2007 | 03:42 PM
  #52
Psykostevo's Avatar
You are always welcome to head down for a tune and car show. It can be fun to hang out with the AZ gang.
If you have an Auto Tranny, I can retune those as well (Flippin' Sweet).
The stock IDC was around 90% too high for performance.
Old 02-02-2007 | 04:17 PM
  #53
UpOnGaMe's Avatar
Originally Posted by g5mike
I can wait,I,m doing my dyno tune in two weeks
I am an 06 as well what are these part numbers?
Old 02-02-2007 | 04:27 PM
  #54
Psykostevo's Avatar
Richie will find out soon. He just got out of the hospital. His daughter has been having surgery. He can find out in a couple days.
Old 02-02-2007 | 11:44 PM
  #55
rukkee's Avatar
I have my stock SS/SC injectors with 4k miles on em . PM me if u want them.
Old 02-03-2007 | 12:09 AM
  #56
LewiSS's Avatar
If the IDC on a stock engine is 90%, then a stock engine (no tune) would still benefit from bigger injectors.
I can never understand why manufacturer's run injectors at such a high IDC. Chrysler is bad about this, too.
Yes, I have the auto. Once someone posts the right wiring harness P/N I'll probably pick it and the injectors up. Maybe in the spring I can make a run out there - it would be a fun road trip, adn it would be fun to play around with a tune. I'm reluctant to get too agressive with the tranny for longevity purposes - I fully agree that the least you should do is a tranny cooler if you ramp up the pressure and firm up the shifts.
Old 02-07-2007 | 02:23 AM
  #57
SSfamliywagon's Avatar
I know I posted this in the other thread, but just in case, I am working real hard on that part number for you guys.
Mike, i saw you posted your doing your dying soon, so I get this part number to you when I get it. Like I said before, I'm ordering different harnness just in case but they won't be in till tommorrow.
Again, sorry for the delay.
Old 02-07-2007 | 01:16 PM
  #58
Psykostevo's Avatar
The part number is 15411879! Yay!
Old 02-07-2007 | 04:35 PM
  #59
g5mike's Avatar
thanks guys,for going through the extra trouble
Old 02-07-2007 | 05:49 PM
  #60
Psykostevo's Avatar
It's all for you buddy!
Old 02-07-2007 | 11:44 PM
  #61
Yeah Mike. Now go finsh your tune and dyno so we can see the true potential of these motors in n/a form.
Old 02-21-2007 | 03:42 PM
  #62
senior_brown's Avatar
ok, so i just came back from the dealership, and they cant find a harness to fit the stock sssc injectors in my car what do i do? my mechanic said he could solder the connections in, but i'd only do that as a last resort,
wtf, my post didnt know uyp
i just came back from the dealership and they cant find a harness to fit the stock ss/sc injectors to my 2.4
what should i do? how many people here can confirm the same part number?
i was also at my mechanics and he said if i want to he can splice and solder the connections for me, but i dont wanna have to do that unless i absolutely have to
Last edited by senior_brown; 02-21-2007 at 03:42 PM. Reason: Automerged Doublepost
Old 02-21-2007 | 03:47 PM
  #63
NightriderCobaltSS's Avatar
Have there been any Dynos yet to see how much power your putting down ?
Old 02-21-2007 | 04:18 PM
  #64
smartmlp's Avatar
You can buy the harness online (part#15411879) for around $58 (Around $47 + $11 shipping) shipped from Gm parts direct
Old 02-21-2007 | 04:58 PM
  #65
pjk91's Avatar
so this part number you are posting, it would allow you to directly connect ss/sc injectors to the eco 2.4?
Old 02-21-2007 | 10:13 PM
  #66
thnx guys, i'll get the dealer to order it in for me tomorow morning i'll call em up
Old 03-05-2007 | 03:42 AM
  #67
part shoudl be here tomorow from the dealer. i looked at a 2006+ 2.2 harness and itwas the wrong one, that part number posted here is a <=2005 models im assuming thats the proper one so i'l find out tomorow
Old 03-06-2007 | 09:37 PM
  #68
Two quick questions for the 2.4's
1. What is the Injector Rated Fuel Pressure for the 35's
2. What is the Fuel Rail Pressure ?
Old 03-06-2007 | 10:15 PM
  #69
mike25's Avatar
not sure off hand but i can check alldata in auto. class tom. and c if i can find it
Old 03-06-2007 | 10:47 PM
  #70
Red2.4SS's Avatar
Fuel rail pressure is 58-60psi.
Old 03-07-2007 | 12:08 PM
  #71
+ Rep
Old 03-07-2007 | 05:41 PM
  #72
Lovethesox's Avatar
Talking i need injectors
Anyone still have their 34# injectors for sale?
pm me thanks
Old 03-07-2007 | 05:50 PM
  #73
zomghax's Avatar
Can injector duty cycle be monitored with an Interceptor, or only through datalogging with HPT?
Old 03-07-2007 | 11:00 PM
  #74
i can confirm this, its in my car with the stock ss/sc injectors right now
Old 03-08-2007 | 01:08 AM
  #75
Psykostevo's Avatar
Yes it can be monitored with both
Quick Reply: New injectors and tune!
