New injectors and tune!
Old 03-16-2007 | 01:29 PM
  #126
g5mike's Avatar
Originally Posted by Psykostevo
The part number is 15411879! Yay!
so this part number is foor a 2005? cause I have a 2006, will i need a 2006 injector harness and whats its parts number?
Old 03-16-2007 | 03:42 PM
  #127
panblackrose's Avatar
You'll be good with the 2005. Nothing else will fit
Old 03-16-2007 | 04:18 PM
  #128
g5mike's Avatar
just paid for it 105.00 canadian it will be here in a week,but I'm in no hurrey for the dyno tune now,my cam problems continue,just found out I have one or more roller rockers broke again.the car goes in on tuesday to be fixed yet again
Old 03-16-2007 | 05:38 PM
  #129
Psykostevo's Avatar
BOOO! WTF is up with those cams?
Keep in mind this is not a part originally intended for the car. It is for the 2001-2004 Ecotec 2.2L. It just happens to perfectly fit the 2.2 and 2.4L harnesses and the S/C injectors PERFECTLY!
IT IS NOT A COBALT PART! That's why we give you the specific part number. It does not matter what year your cobalt is, the P/N will work.
Old 03-16-2007 | 06:33 PM
  #130
g5mike's Avatar
thanks! and that cause ita the only plug and play?
Old 03-16-2007 | 08:41 PM
  #131
Cobalt_Supercharged's Avatar
Right. GM happened to make a harness that would connect to the 2.2/2.4 harness and LSJ injectors.
Old 03-18-2007 | 02:37 PM
  #132
I think its a conspiracy. They're checking how smart we are, and planted a 2.2L harness that just happens to fit the LSJ injectors AND plugs into the 2.4L with a tune. CONSPIRACY DAMMIT! Stevo, when can I expect that tune? Please dont take off torque management, I just reflashed to stock yesterday and noticed a difference when I put it back on. Less problems and noises. You set the limiter for 7000 right?
Old 03-18-2007 | 10:26 PM
  #133
Psykostevo's Avatar
I just sent you the file to your email address :-)
Old 03-19-2007 | 12:36 AM
  #134
Awesome! I haven't put the injectors in yet, but I did take a look at it. How much did you want again? As for the wait, no problem, I had to wait for the harness and muffler anyways. I want to do a dyno soon as well. Thanks man, we shall see what this will do for my car!
I sent a reply through yahoo, stevo
Last edited by panblackrose; 03-19-2007 at 12:36 AM. Reason: Automerged Doublepost
Old 03-19-2007 | 10:22 AM
  #135
thekingsSS's Avatar
If you switch the injectors will it work with a Vector tune? Or can you only use HP Tuners?
Old 03-19-2007 | 11:04 AM
  #136
06blackg85ss's Avatar
Originally Posted by Doc
I'm glad you got some positive results from this mod.
on a sidenote, did you have issues with HPTuners after you flashed the 2.4..? I had to completely uninstall and reinstall it to get it to read or flash a 2.0.
Mine did the same thing this weekend, I tuned illmatcs car a little bit more (still waiting for him to get the harness for the injectors) and I went to do redlinebrians car sunday morning, and it wouldn't connect, I had to install and uninstall like 3 times before I got it to read again. And yes it won't do the write callibration only, have to do full write. PITA! lol
Old 03-19-2007 | 01:11 PM
  #137
Psykostevo's Avatar
Definitely a PITA. If you do a write calibration only on the Automatics it will wipe the VCM clean. I hate how the only way to flash it is to do teh Write Entire. Too risky IMO, but maybe its because it has to write the VCM and the TCM.
I think you guys are right, that might explain why my HPTuners always needs to be reinstalled, I didn't relate it to the 2.4L's
Old 03-19-2007 | 01:15 PM
  #138
yeah I hear ya on that, just the reinstall everytime I switch cars is a pita... thank god I had the software with me yesterday. coulda sucked
Old 03-19-2007 | 02:47 PM
  #139
Psykostevo's Avatar
I keep all of my files on my phone so I always have them with me. Never know when you need a reinstall.
Let me know what you think of the tranny retune :-) I bet you are going to like it.
Old 03-19-2007 | 03:21 PM
  #140
senior_brown's Avatar
its not jsut the automatic 2.4 that need the "write entire" 5spd too
Old 03-19-2007 | 03:34 PM
  #141
pjk91's Avatar
Thumbs up
I'm not sure if you understand what a tune is. A tune is basically modifying the car's computer to understand what you have done to it (put in new injectors) because you now have more fuel. Before a tune (modification to computer ecu), the ecu would not know what to do with that extra fuel and you would be dumping way too much into the cylinders and then you would be pig rich, your car may not start or idle or you will burn out the cat...or any number of other issues.
So yeah, vector can more than likely tune your ecu if you tell them you swapped injectors to the 2.0 s/c stockers. Or someone with HPT will be able to tune your vehicle.
In my opinion, a Vector tune would not be a good idea in this situation because not many 2.4L have done this yet. You may be their first 2.4L with s/c injectors at Vector. With HPT, the same issue can still happen, and a mail order tune from an HPT guy may or may not be good for you.
Your best bet is to find someone near you with HPTuners if you do decide to go with the s/c injectors for your 2.4L.
Old 03-19-2007 | 03:36 PM
  #142
lol. I do the same thing too... Nextel Memory card FTW!!!... also e-mail them to my desktop so I have em saved in multiple locations just in case.
Old 03-19-2007 | 03:41 PM
  #143
RaineMan's Avatar
Damn... so do they make upgraded or stronger roller rockers than stock? Obviously the stockers aren't designed to take the kinda stress the cam is putting on them.
On another note... what does your idle sound like with that cam? Sound clip?
Old 03-19-2007 | 04:00 PM
  #144
Hey mike, were those the "new" version for the 07's.???
Old 03-19-2007 | 04:04 PM
  #145
Psykostevo's Avatar
Yup I use sprint. My phone is my life. I use it for my 2.0megpixel camera, where all my pics come from. It's my Camcorder, I have a 1 GigHD (soon to be 2 gig) in it, and I use it for Ebay, and the net, TV, radio, etc. Love this Samsung A940!
Old 03-19-2007 | 04:05 PM
  #146
nice man... I got the motorola i870.. just got a new digital camera/video camera though. so I'll be posting up some nice vids this summer.. gonna do some log runs tonight and I"ll record those just to figure out how to use the damn thing
Old 03-19-2007 | 04:10 PM
  #147
Psykostevo's Avatar
Cool, why Nextel instead of Sprint?
Old 03-19-2007 | 04:46 PM
  #148
Doc's Avatar
Doc
I'm not that hi-tech...I have a 2 gig flash drive I save everything to.
  #149
elmstreet's Avatar
ew sprint.. lol i work in a sprint call center.. either sprint's towers really suck or just that many people have nothing better to do than to call in and lie to me
Old 03-19-2007 | 05:10 PM
  #150
Psykostevo's Avatar
They must be liars. I love my service!
Quick Reply: New injectors and tune!
