New injectors and tune!
Old 03-30-2007 | 03:44 PM
  #201
thekingsSS's Avatar
Originally Posted by zomghax
God dammit, a local dealer wants $157.75 for that harness...
I dont know if GM Parts Direct ships to Canada or not, but if they do the harness is only $53 US on that site
Old 03-30-2007 | 03:52 PM
  #202
zomghax's Avatar
Thanks for the idea, I will give them a call.
Old 03-31-2007 | 03:04 AM
  #203
g5mike's Avatar
Originally Posted by panblackrose
Attention!!! Use Your Stock 2.4l Injector Clips When You Swap!!!! If You Don't, The Original Ss/sc Clips Will Pop Off!! It Just Happened To Me On The Highway, But Luckily I Had The Tools And The Other Injectors And Clips In The Car. Beware!! Fuel Will Spray Everywhere!!!
thanks for the heads up!
Old 04-02-2007 | 01:04 AM
  #204
zomghax's Avatar
Tuning for larger injectors?
Regarding HP Tuners and how to tune for larger injectors, I'm a bit confused. Here is a link to the HP Tuners How-To on tuning larger injectors:
http://www.4cyltuner.com/Forum/viewtopic.php?t=5
According to that, all you need to do is change the injector constant using this forumla:
Injector Constant = Old Constant * (Old Injector Size / New Injector Size)
Is that really all there is to it? Earlier in the thread, Pskostevo said:
No, I guess that would have worked too, but I just calculated the Flow rate the good old fashioned way. 34/24=1.4166667 x all values in table.
Sounds like he used an inverse formula and changed many values, not just one.
Can someone please post up some screenshots and show what exactly needs to be changed in HP Tuners to tune the 2.4L for larger injectors?
Old 04-02-2007 | 04:15 AM
  #205
Psykostevo's Avatar
There is no injector constant on the 2.4L or the 2.0L. That was used on older motors, you actually have to adjust an entire flow table. But the principle behind calculating the difference still remains the same.
Old 04-02-2007 | 11:01 AM
  #206
zomghax's Avatar
Thanks for the clarification Stevo.
Old 04-05-2007 | 02:23 PM
  #207
zomghax's Avatar
Well GM Parts Direct won't ship to Canada, but NewGMparts.com (Puritan Pontiac) would. It was $68 from them plus ~25 shipping, which will still be cheaper than local even with tax and brokerage when it arrives.
Old 04-05-2007 | 02:49 PM
  #208
Psykostevo's Avatar
Good deal, junk yards are still a dime a dozen, but then again not everyone wants to go fight aids infested dumpster rats for injector harnesses.
Old 04-05-2007 | 05:26 PM
  #209
zomghax's Avatar
AIDS infested dumpster rats > me
lol
Old 04-06-2007 | 12:07 AM
  #210
rlinden86's Avatar
Need SS/SC Harness
does anyone have a harness for the stock 2.0 injectors for sale. im looking to add the sc injectors to my 2.4. would that work guys?? put on the 2.0 injectors and the harness with it it shouldnt have a problem after i tune it hptuners. how much for harness if anyones got it.???
ryan.
Old 04-06-2007 | 03:12 AM
  #211
Psykostevo's Avatar
ryan.
Please read this thread. You need a special harness from earlier ecotecs. The 2.0L harness does not fit the 2.4L setup, and the 2.2L and 2.4L cobalt harnesses don't fit the 2.0L injectors. We have listed the specific part number you need.
Happy modding!
Old 04-06-2007 | 04:35 AM
  #212
Lovethesox's Avatar
i put my ss/sc set up in today with the new tune from bryan herter....pcmforless.com
my car rips now def woke it up ALOT....so all you who say mail tunes are wrong, trying to get it dyno'd tomorrow, well today i guess its 430 in the am but hopefully ill have some numbers by later tonight...
Old 04-06-2007 | 10:05 AM
  #213
rlinden86's Avatar
Part num
is the part number 1541879 or is that for injectors i dont know how to search and find whatever that is. or you could just tell me where i could find a harness for those 2.0 injectors for my 2.4.
ryan
Old 04-06-2007 | 10:08 AM
  #214
zomghax's Avatar
ryan
Read this entire thread. Every post. A few times.
Old 04-06-2007 | 10:13 AM
  #215
rlinden86's Avatar
2.2L harness
Actually colbaltcrusin, I don't know where you could find out about tunes. I learned all my info from pyskostevo here in AZ.
Well I'm gonna let you guys in on a little secret. There is no special wire splicing or cutting needed. Don't even need to take out the electical tape. The special harness needed is none the less a 2.2l harness. Everthing is plug and play and I have to say the easist mode. Only took 10-15mins max. Then you just have to have it tuned.
I say $50 is a fair price. Our buddy is getting some for around that price. By the way the price for the 2.2l harness was $31.00 my cost. Don't know list price since I get employee discount.
I just returned from the Chevy dealer with my 2.2l injector harness, and guess what?
It doesn't fit my ss/sc injectors. The harness clips are much bigger than the injector fittings. I ordered GM part#1582220 which is supposed to fit a 2005 2.2l.
Again, this part doesn't fit, so don't order it.
So i can get the 2.2l ecotec cobalt harness for the 2.0 stock injectors for my 2.4 cobalt engine. gees that sounds weird for all that crap.. if thats what im reading will that work. so i read alittle bit the correct part # is 15411879. for the harness 2.2l for stock 2.0 injectors. now all i should have to do is put the new injectors in and that harness and then all my exhaust and intake mods and then take it to get tuned and should run fine correct.
ryan.
ryan.
Old 04-06-2007 | 11:42 AM
  #216
Psykostevo's Avatar
ryan.
No, it is not a COBALT harness it is a CAVALIER/SUNFIRE harness. Many people have ordered the cobalt 2.2L harness because they have not paid attention. It is specifically the part number listed in this thread. You are correct #15411879.
AGAIN DO NOT ORDER THE 2.2L COBALT HARNESS. :-) I have to strongly clarify that because people are confusing the matter.
Old 04-06-2007 | 12:29 PM
  #217
rlinden86's Avatar
Not at dealer is it
so you think that part # is at the dealer under say a cavi from 04. cuz the # comes up for a 05 06 balt 2.2 and its the harness?? do you think it could have the same # but its different harness and for the cavi from 04 is that right. or where could i get one....
ryan.
Old 04-06-2007 | 10:03 PM
  #218
gmaddict's Avatar
yes 04 cavi/sunfire 2.2(ecotec) fits and works nothing older, anything older is all one huge engine harness. Lovethesox's car gained about as much power from the tune/injectors as he did from the header but thats just sotp/butt dyno. Dyno on monday @1pm!
Old 04-07-2007 | 01:14 AM
  #219
rlinden86's Avatar
Cool
So i have to find a 04 cavi harness with this part num that i have. gees i wonder if anyone on here has them... pffh anywhos let me know how that tune and stuff works and that dyno the numbers on that harness and injectors.
ryan.
Old 04-19-2007 | 09:51 AM
  #220
panblackrose's Avatar
I've been running the injectors and slight tune for a while and no issues. I dont feel very much of a gain after a while, but I think its also running pig rich. That wont matter soon though once I get my T04E in and put on
Old 04-19-2007 | 10:05 AM
  #221
zomghax's Avatar
Got my harness, got my injectors, just trying to arrange some HP Tuneage with some friends of mine!
Old 04-25-2007 | 08:22 AM
  #222
koribenton's Avatar
Does anyone know where i can get a tune, i live on the east coast of Florida!!!! thanks, i have a set of s/c injectors and harness ready to go
Old 05-08-2007 | 07:38 PM
  #223
Psykostevo's Avatar
Was yours the one that had the injectors put in wrong?
Old 05-08-2007 | 11:54 PM
  #224
rlinden86's Avatar
hey stevo
hey stevo meant to say thanks the tune that you sent me i used it in conjunction with wickedss2005 hptuners and got him to unlock all the 06 2.4s and we put in the 2.0 injectors in my 2.4 and tuned her up and runs amazing. definatly have to dyno her and run it down the track.
ryan.
Old 07-30-2007 | 10:42 PM
  #225
g5mike's Avatar
Bumping up this thread for you 2.4 guys goin with the Rebel setup you are gonna want this harness
Supercharged06SS
12-11-2022 04:47 PM
05-28-2022 03:47 AM
no_ss
10-18-2015 11:58 PM
10-13-2015 09:32 PM
anotherslowlnf
09-29-2015 03:52 PM
Quick Reply: New injectors and tune!
