Now that I'm SC'd, what's next?!
So now I'm looking at engine longevity as well as performance. Now I'm ready to mod my own car. So here's what I'm thinking.
2.9" pulley
OTTP stg 1 heat exchanger
2.5" ZZP cat-back exhaust
80# injectors
E85 tune by HPT
Rebuilt M62
KY Stage 3 clutch
I think this will really make my car come alive and enjoyable. Of course this is my daily driver, so I'm not going hardcore with mods. But I would like to hit 265-280 whp.
If anyone has some better suggestions or tips please feel free to throw them at me!
2.9" pulley
80# injectors
E85 tune by HPT
Rebuilt M62
KY Stage 3 clutch
Pulley down...
Then get bored with the power
TVS...
Turbo
but in all seriousness, your list looks fine. You'll only need 60's even if you wanna do E85. Here are my suggestions:
2.8" pulley
ZZP S3 heat exchanger
dual pass and option B
ZZP phenolic IM spacer
2.5" ZZP cat-back
Seimens 60s
New tune by HPT
KY Stage 2 clutch
TVS...
Turbo
2.8" pulley
2.5" ZZP cat-back
Seimens 60s
New tune by HPT
KY Stage 2 clutch
60s wont work on 2.8 if you're doing e85 imo. I'm already seeing 90+ IDC with 60s on a 2.9. And yes bored with the power its making lol. Thinking I wanna put some good pistons in it before I go for more power
I'm uncertain of the E85, I haven't done any research on it's pros and cons.
I've had a few people suggest a KY clutch so I will be trying to shop for one of those. I know I'll get bored with the power, but I'll be content.
E85 has a higher octane rating which makes it less likely to knock than 93 octane would. BUT it has a lower energy content and takes more fuel to run properly. Hence why you need bigger injectors for it. The way it helps make more power is you can run quite a bit more timing and get away without knocking. Lower combustion temps also. Should see ~20hp gain? Maybe more.
oh and another pro - it smells nice
being in california the available E85 should be much more abundant, we only have like 2 stations within 50 miles around here for E85 which is the reason why i never wanted to convert any of my vehicles over to it. It is however much harsher on your fuel system and seals compared to regular gasoline, and you do require much much more of it because it puts out less energy then gasoline does when burned, but it is much more stable then 110 race gas by comparison.
You can also get very close to similar gas mileage with E85 if you tune the spark timing in cruise areas also, I get 29 mpg on E compared to 33 on gas previously.
What do you mean by stable?
I think all newer cars theoretically could be tuned to run on E85 simply because even gas is still E10 or E15.
E85 is "less stable" than race gas (110) because of E's lower latent heat than gasoline, which causes pre ignition not detonation. E85 has about 97 octance rating, but it is debated. It's resistance to knock is approximately 85-90% of 110 race gas. The octane or "detonation resistance" is nowhere near 127 and is not as good as race gas.
Lol every thread where E gets brought up turns into a "I love E" thread.
my information is probably just wrong from the v8 guys that tout it as the greatest thing ever. I know with methanol injection we were able to get anywhere from 97 to 116 octane "rating" depending on the concentration. I was always told E85 was higher, but race gas has come a long way. Chris millers FTW purple race fuel (oxygenated E85) produced significantly better results then E85 or VP race gas ever could.
