Now that I'm SC'd, what's next?!
#239
im running ZZP s3 and a dual pass intercooler. Intake temps about 25-30 degrees above outside air. and less than 120 at WOT for the most part unless im doing a ton of pulls. seems to do fine. Going to run an LSJ intercooler in line with it also, but i haven't installed it yet.
#243
http://www.ebay.com/itm/BLACK-7-x-3-x-2-5-SQUARE-OIL-CATCH-CAN-TANK-RESERVOIR-W-DRAIN-PLUG-NISSAN-/350832104211?pt=Motors_Car_Truck_Parts_Accessories&hash=item51af391313&vxp=mtr
Works Perfect
Works Perfect
#244
I did notice a but of oily crap on intake parts. Perhaps I'll pick up this catch can. Then I'll need to plug the opening on my intake.
I heard from someone that you can see the coolant moving in the surge tank. Is this true? I don't see anything happening when I pop the cap.
#245
the catch can has an in and an out. so the hose goes to the can then from the can to the intake. so you dont need to plug it. The coolant in your option b tank or your cars regular coolant?
#247
On the LSJ tb, there is a forward facing brass connection. What do I hook up to this? Currently, I just have it capped off. Once I installed the new tb, and changed the scalar in hpt, I started my car and it ran like hell.
Popped the hood and heard some gnarly hissing coming from that port. No idea what connects to it, so I just capped it. Seems to be running ok, except for throwing p0106 often. P0106 is throttle position sensor code. Perhaps I have a vac line that isn't hooked up right now and it's just chilling somewhere in the engine bay?
#249
#250
