Now that I'm SC'd, what's next?!
Old 08-26-2013 | 01:23 AM
Jacob4ta's Avatar
So if your pulley determines how much boost you will make, how can you be sure you won't over boost? Or is it just a matter of upgrading engine internals so that whatever you do boost, you'll be safe?
Old 08-26-2013 | 01:34 AM
redcobalt07's Avatar
I would do clutch first, you are gonna kill it soon with that power.
Old 08-27-2013 | 01:29 AM
Jacob4ta's Avatar
Just ordered ZZP's 3" intake as well as a brand new LSJ throttle body and 8 pin to 8 pin adaptor. Hopefully they will be here by the weekend so I can install and have some fun!
Old 08-27-2013 | 09:35 AM
Twoozofjuice's Avatar
How abouy I send you a 3.1 pulley so you can have a bit more fun lol. It's safe to run lol
Old 08-27-2013 | 10:45 AM
Jacob4ta's Avatar
Then I need to switch to a modular setup. I have no tool for that crap
Old 08-27-2013 | 12:17 PM
Chaos_Six's Avatar
You can also use a standard 3 jaw puller and an impact wrench if you have access to them. That's what I used. What did you use in the intake manifold as far as hardware? I'm talking about the 2 middle holes that go far through the manifold and into the block. Do you recall the size?
Old 08-27-2013 | 07:53 PM
Jacob4ta's Avatar
Not sure on size, pk91 (Pat). Picked up the hardware at a store called fastenall or something similar.
So a regular gear or hub puller will take a stock pulley off? I don't need some special tool that ZZP sells?
Old 08-27-2013 | 08:08 PM
Idk you prolly don't need that special tool but if you do you could always rent it lol
Old 08-27-2013 | 09:27 PM
pjk91's Avatar
lol, good luck getting that pipe in there!
Old 08-27-2013 | 10:06 PM
Jacob4ta's Avatar
I'm probably going to fab a bit of the support that the I take tube snakes around. I may just cut some off of it so that it fits happy underneath it.
Reviews say that it's not too bad of a fit, but rubs against the ECU.
Old 08-27-2013 | 10:41 PM
  #36
My zzp 3in intake fits pretty easily. I did have to cut and bend some parts though lol
Old 08-27-2013 | 10:51 PM
  #37
nhanson's Avatar
Mines just in there. Not secured..its a tight fit.
Old 08-27-2013 | 11:26 PM
  #38
Chaos_Six's Avatar
Correct. If you have one that will work just fine. That's how I took mine off.
Old 08-29-2013 | 12:42 PM
  #39
Jacob4ta's Avatar
I never asked this, but what are an SCd LE5's limitations on injectors, and a pulley with an M62? Without doing internals work.
Old 08-29-2013 | 01:47 PM
  #40
nhanson's Avatar
On your 42s?
Old 08-29-2013 | 01:50 PM
  #41
Chaos_Six's Avatar
Originally Posted by nhanson
On your 42s?
This.
If you have 42s and want to go for a smaller pulley I'd get bigger injectors first.
Old 08-29-2013 | 01:57 PM
  #42
nhanson's Avatar
80s with E85
Old 08-29-2013 | 04:49 PM
  #43
pjk91's Avatar
I think Beck is running e85, 2.8 on 80s. He's probably north of 280whp. There are turbo LE5s running around with 330-350whp, stock internals. It really depends on how hard you're driving it too.
Old 08-29-2013 | 04:53 PM
  #44
zerosk8ter83's Avatar
whats next? turbo that shet man!
Old 08-30-2013 | 01:16 PM
  #45
Avalanche687's Avatar
Twin charged LE5.
Old 08-30-2013 | 11:37 PM
  #46
Chaos_Six's Avatar
Originally Posted by Avalanche687
Twin charged LE5.
I thought about twincharging, but I only have ever read bad things about that. :P
Old 08-31-2013 | 12:12 PM
  #47
Ive
I've never seen a twin charged le5 so I'm curious lol
Last edited by Avalanche687; 08-31-2013 at 12:12 PM. Reason: Automerged Doublepost
Old 08-31-2013 | 01:59 PM
  #48
Spawne32's Avatar
twin charging would be more harmful then helpful on a 4 cylinder, unless you used two really really tiny turbos lol
Old 08-31-2013 | 02:08 PM
  #49
Chaos_Six's Avatar
Is that even possible? Twincharging is supercharged and turbo'd...
Old 08-31-2013 | 02:09 PM
  #50
Beck's Avatar
my zzp 3" intake easily fit without any rubbing issues. Not sure why everyone has problems with them.
