Now that I'm SC'd, what's next?!
So if your pulley determines how much boost you will make, how can you be sure you won't over boost? Or is it just a matter of upgrading engine internals so that whatever you do boost, you'll be safe?
You can also use a standard 3 jaw puller and an impact wrench if you have access to them. That's what I used. What did you use in the intake manifold as far as hardware? I'm talking about the 2 middle holes that go far through the manifold and into the block. Do you recall the size?
Not sure on size, pk91 (Pat). Picked up the hardware at a store called fastenall or something similar.
So a regular gear or hub puller will take a stock pulley off? I don't need some special tool that ZZP sells?
Idk you prolly don't need that special tool but if you do you could always rent it lol
#38
Correct. If you have one that will work just fine. That's how I took mine off.
#43
I think Beck is running e85, 2.8 on 80s. He's probably north of 280whp. There are turbo LE5s running around with 330-350whp, stock internals. It really depends on how hard you're driving it too.
#47
I've never seen a twin charged le5 so I'm curious lol
Last edited by Avalanche687; 08-31-2013 at 12:12 PM. Reason: Automerged Doublepost
#49
