Phantom Noise..?
Phantom Noise..?
Hey guys,
Ok.. So recently I've been having a noise under my hood. It's a very steady beeping noise. Every second, a beep. It's coming from my valve cover, right over my injectors. But it's only while at idle. As soon as I give it gas, it stops until it reaches idle again. It's quite a loud noise. I do have a SRI intake and a ram-air hood, but it just seems quite loud for what it is.. I wasn't sure if it could've been a belt, but it's coming from the top of the engine. Has to be something in the injectors or something? My car isn't due for inspection for another month, and I hate taking it there when there isn't a real problem. The car is running perfectly fine, aside from a tiny drop in MPG recently and coolant temps rising every once in a while as well.. It has a mind of it's own.. Any ideas? Will it hurt anything or just be annoying? lol.
Also, if it IS the injectors, are the s/c injectors a good idea? I heard they really don't help much over the 2.4 ones unless you boost? And you need a tune or something anyway? Info?
Thanks!
Thanks!
There is nothing electrical that would cause a 'beep' around the injectors. Unless maybe the injectors have a new fail system that beeps to let you know its failing...but ive never heard it.
call the stealership and ask what it could be.
It's most definitely the top. But it stops when the car is accelerating. Lightly or heavily - doesn't matter. But it beeps when it's idling. I guess it's not too big of a deal since the car is running great.. I'll just wait it out until I take it for inspection in a month..
Video:
http://s48.photobucket.com/albums/f2...t=DSCN1109.flv
The beep is clearly heard. Although you can't quite tell from the video that it's from the top..
