picking up a 2.4 auto, need some opinions
Old 06-20-2013 | 11:49 PM
Ceeker's Avatar
Originally Posted by Spawne32
so none of you have ever had the timing chain done?
I did serpentine and timing at 60k miles when I went turbo. Not because they failed, mostly because I had everything all apart anyway/ preventative maintenance
Supposedly timing is good for the life of the motor /180k miles
Old 06-21-2013 | 11:18 AM
nhanson's Avatar
Im reusing my timing set on 118k with my build
Old 06-21-2013 | 02:29 PM
Spawne32's Avatar
really lol i always thought the chains stretch some and its a good idea to replace them when they are exposed
Old 06-21-2013 | 03:25 PM
Spawne32's Avatar
Im a little confused about the 2.4's internals, on one article i have it says it uses standard powdered steel connecting rods, where as the LSJ used forged steel, and in the article i have from 2009 where the 2.4 eco was awarded wards north american top 10 engines of the year it claims to have forged connecting rods. However the version they listed was direct injection.
Old 06-21-2013 | 03:30 PM
chevygirl2006's Avatar
I think the 06 and 07 have forged rods.
Old 06-22-2013 | 12:24 AM
Mindrot's Avatar
Bingo
Old 06-22-2013 | 12:32 AM
Spawne32's Avatar
well that is very good to know
Old 06-22-2013 | 01:46 AM
Ceeker's Avatar
I believe 2005 do as well
The LE5 is multi port fuel injected
The LE9, LAF, LEA, LUK, are all direct injection
Old 06-22-2013 | 02:10 AM
There's not a 2005 2.4
Old 06-26-2013 | 12:53 AM
Spawne32's Avatar
So i picked her up tonight and was able to get a better idea of the issues that are going to need resolving, there are no active codes or lights on the dash thus far, however the gauge pod looks like it has been disassembled at one point in time, with the lights on you could see the face plates are not in the correct position, which explains why none of the needs are in their correct positions, so i decided to not even bother with fixing that just yet and just ordered a 06 160mph gauge pod off ebay for 70 bucks shipped.
The hard shifting seems to just be VVT solenoid related, the car falls on its face at WOT through the mid range, which I would attribute directly to that, or needing a tune up. The car has def had maintenance at regular intervals though, it has a walmart oil change sticker on the windshield showing its been getting regular 5w30 oil changes, the coolant was of a new color in the bottle, and the trans fluid im going to be changing anyway. Steering is a little loose, i imagine it needs tie rods, which is no big deal. Brakes were horrific, so im doing those tomorrow morning along with a oil change to rotella T6.
The power locks dont work with the lock switch, so i ordered a replacement master switch off rock auto for 9 bucks, gonna try replacing that first, that might be my lock issue, ill have to do a passenger side window motor soon enough, but it is still moving thus far. Also going to have to inspect the regulator as it looks like the window rocks a little bit as well.
I only got one key with the car, and no keyless entry keyfob so im not even sure if it has it, ill have to swing by the stealership and have them run the vin and see what options it was equipped with, how much a spare key is going to cost me, and if the recalls has been repaired at all.
Old 06-26-2013 | 12:59 AM
  #36
Mine only came with one key as well. So how much did you pay for it?
Old 06-26-2013 | 01:09 AM
  #37
Spawne32's Avatar
4000 including tax, 127,000 miles
Old 06-26-2013 | 01:11 AM
  #38
Wired's Avatar
I loved my 2.4. It was bulletproof until around 75000 when I had to replace injectors and the evap purge solenoid. I just did regular maintenance. It was a 2007.
Old 06-26-2013 | 01:12 AM
  #39
How do you know when your injectors are bad?
Old 06-26-2013 | 01:17 AM
  #40
Spawne32's Avatar
ive only worked on one other car that had bad injectors, and it had a persistent misfire that was unrelated to ignition components, only way i was able to narrow it down was to move injectors between cylinders and the misfire followed it to the other cylinder.
Old 06-26-2013 | 01:20 AM
  #41
Would I get a CEL?
Old 06-26-2013 | 01:25 AM
  #42
Spawne32's Avatar
you would get a misfire code, but as far as i know theres no way for this car to monitor injector's as far as performance goes, redlines fuel injector cleaner (and no others) is a good way to keep your injectors clean. Its the highest concentration of actual cleaning agent available on the shelf. All others like STP and such are just kerosene and petroleum distillates in a bottle, if you look at their MSDS sheets.
Old 06-26-2013 | 01:38 AM
  #43
zerosk8ter83's Avatar
proud owner of a 06 2.4. I purchased mine with around 66k miles on it last year and it runs great.
Old 06-26-2013 | 12:46 PM
  #44
Spawne32's Avatar
Well, here she is, in all her hooptieness. Washed and cleaned to the max, i need to clay bar the sides and compound and polish, and then get a quote from maaco for repainting the hood roof. Couple shots of her next to the old hotness, and my brothers ford hotness in the background lol covered with the tarp. Cant wait to get down on that POS, hopefully i can convince him to throw a 302 in there.
did the front brakes today, got a frozen slide pin on the pass side, couldnt change the oil, walmart who was previously doing the oil changes wrecked the oil pan plug and decided it would be a good idea to loctite it to the pan. Had to pick up a new plug today, gotta take a crack at that tonight if it cools down. Also found these disgusting messes of air filters, the car has seen no love whatsoever. You can also see in one of the pics above that the gauges are all fucked up, ordered a new pod from ebay.
Old 06-26-2013 | 01:30 PM
  #45
Twoozofjuice's Avatar
atleast yours had a filter...lol my friend bought one and it looked like someone shoveled dirt on the engine bay. didn't have a air filter either and was "tuned" lol.
Old 06-26-2013 | 01:36 PM
  #46
Spawne32's Avatar
lol thats pretty bad, yeh this thing needs some love, i realize now why the gauges are all jacked up, someone removed the check engine light bulb, so i gotta get my scan tool and see whats going on.
Old 06-26-2013 | 01:38 PM
  #47
the little square led?
Old 06-26-2013 | 01:41 PM
  #48
Spawne32's Avatar
that would be the one
Old 06-26-2013 | 01:52 PM
  #49
pretty messed up lol coulda just taped over it from the back instead of ripping off the led -_-
Old 06-26-2013 | 01:55 PM
  #50
Spawne32's Avatar
tell me about it, no matter, easy fix IMO lol the oil pan bolt has me stressed out right now
Quick Reply: picking up a 2.4 auto, need some opinions
