picking up a 2.4 auto, need some opinions
Old 07-08-2013 | 12:05 PM
  #76
Spawne32's Avatar
car revs like a damn dirtbike now, god only knows what my long term fuel trims must have been, ive seen clogged filters before, where if you blew on the in side you couldnt get anything through the out side, this thing was so bad black **** was pouring out of the in side. Hopefully i can get it to pass state inspection today after i replace the vvt solenoid on the exhaust side in a little bit. That should be pretty much it except for the evap code which hasnt come back, and i found that my gas cap was left completely off last time i filled up for gas.
Old 07-08-2013 | 12:08 PM
  #77
Twoozofjuice's Avatar
they strict on inspection over there?
here they don't give a crap lol. My car was barely able to stay on when I went to do inspection and I even had catless dp and they didn't care. oh and my ebrake doesn't work lol
Old 07-08-2013 | 01:20 PM
  #78
chevygirl2006's Avatar
We have emissions here apparently. Found that out.
Old 07-08-2013 | 01:23 PM
  #79
really? lol. sucks
Old 07-08-2013 | 01:28 PM
  #80
SalvageBaltSS's Avatar
nice car, didn't feel like reading all the posts' so how much you pay? lol remove pin striping
Old 07-08-2013 | 01:31 PM
  #81
go back and read them or else imma put that curse on you from holes.....
i'm bored at work in case you can't tell -_-
he got a pretty good deal on the car just has to do a little work on it which isn't too bad
Old 07-08-2013 | 01:38 PM
  #82
Ya so no catless for me. He paid 4k
Old 07-08-2013 | 01:39 PM
  #83
you could do catless. just throw on stock dp when you're gonna do emissions
Old 07-08-2013 | 01:41 PM
  #84
Idk if a stock LNF downpipe would fit. Since its an aftermarket kit I wasn't sure if it would work. I was thinking about that the other day.
Old 07-08-2013 | 01:43 PM
  #85
true. might have different uhhh manifold thing or whatever.
Old 07-08-2013 | 02:20 PM
  #86
Spawne32's Avatar
welp, failed inspection, system readiness not ready on evap and heated o2 sensor, threw a code for cylinder trim balance and random multiple misfire
Old 07-08-2013 | 02:23 PM
  #87
sucks turtletits :/
Old 07-08-2013 | 02:30 PM
  #88
Spawne32's Avatar
looks like im gonna be replacing fuel injectors
Old 07-08-2013 | 02:41 PM
  #89
I coulda helped you out with that....lol I have my stock ones laying around somewhere -_-
Old 07-08-2013 | 02:45 PM
  #90
Spawne32's Avatar
if you find them that would be fantastic, i havent ordered new ones yet, they worked good when you had them in?
Old 07-08-2013 | 03:11 PM
  #91
Spawne32's Avatar
got to install my new VMS antenna this morning, ripped the antenna housing right off the shitty spot welded mount in the trunk but that thing holds tight as **** in the rubber base when you push it back up in.
Old 07-08-2013 | 03:19 PM
  #92
worked just fine. went sc so had to replace. I know I can find 1 or 2 atleast lmao I will look for them all
Old 07-08-2013 | 03:31 PM
  #93
Spawne32's Avatar
yah please let me know lol if i dont have to pull the trigger on 130 dollars worth of injectors that would be fantastic
Old 07-08-2013 | 03:36 PM
  #94
alright im out at 5 so I'll go look for them then
Old 07-08-2013 | 08:42 PM
  #95
Spawne32's Avatar
any luck finding those injectors? lol
Old 07-08-2013 | 09:23 PM
  #96
buildmeanempire's Avatar
Wow. Hope you get everything sorted out and don't end up with a $4,000 lawn ornament.
Old 07-08-2013 | 09:47 PM
  #97
I had forgotten about them lol sorry. Ok well here's the story. 3 injectors have been inside my house laying around. The other was laying around also but then I blew a seal on one of my current injectors and I tried replacing it with the seals from this one. Well they were too big lol. But yeah that one stayed outside in my tool box. Its the one on the far right.
Old 07-08-2013 | 10:11 PM
  #98
Spawne32's Avatar
how much you looking to get for them?
Old 07-08-2013 | 10:14 PM
  #99
idk lol pm me
Old 07-12-2013 | 02:32 PM
  #100
Spawne32's Avatar
got the fuel injectors today twooz! thanks, bathed them in laquer thinner for 15 minutes and installed them and they ran great, dunno if that code is gonna come back though. Still have an occasional hesitation when you blip the throttle hard. Dunno what its related to.
Quick Reply: picking up a 2.4 auto, need some opinions
