Pieces of metal in oil filter?
Old 07-27-2008 | 03:09 PM
SI FTL's Avatar
Ok, no bashing.. lol I've never seen this before so when i looked at it i was kind of dumb founded. Car has 4,800k on it and i am doing it's first oilchange. The stock filter if you look through it has little shrouds of metal in it.. Is this normal? part of a break-in cycle or should my ass be heading to the dealer..
Old 07-27-2008 | 03:12 PM
dsp86's Avatar
its perfectly normal nothing to worry about all ecotechs have specs of metal in the oil filter the first oil change. i have done a bunch of first oil changes on these engines. its just left over **** from when the engine was machined.
Old 07-27-2008 | 03:13 PM
SI FTL's Avatar
Thanks.. lol i've never seen it before.. but then again this is the first vehicle i've owned w/ a drop in.. Again, much appreciated!
Old 07-27-2008 | 03:37 PM
boose00's Avatar
the engine parts need to wear into each other. You should of changed the oil at 500 miles to get that out but i dont think you are in any kind of trouble. I saw the same thing in my grand prix when i did the transmission fluid and the mechanic said thats normal.(shavings not chunks of metal to clarify)
Old 07-27-2008 | 03:41 PM
EXsoccer1921's Avatar
4,800k??? you mean 4,800 miles? or 4,800,000?
Old 07-27-2008 | 03:46 PM
bridfi's Avatar
kilometers
Old 07-27-2008 | 03:48 PM
Beck's Avatar
yer speshul
Old 07-27-2008 | 05:20 PM
SI FTL's Avatar
lol. four-thousand eight hundred
Thanks everybody
Old 07-27-2008 | 05:42 PM
Originally Posted by bridfi
kilometers
way to not look to see where he lives
Thanks everybody
i'm just messin around with ya, i know you meant 4,800miles
Last edited by EXsoccer1921; 07-27-2008 at 05:42 PM. Reason: Automerged Doublepost
Old 07-27-2008 | 08:26 PM
bridfi's Avatar
what the **** else would k mean
******* fagot
whats just north from NY? CANADA.
Old 07-27-2008 | 08:31 PM
Red2.4SS's Avatar
km = kilometers
k = thousand! haha
Anyways as long as this doesnt happen on the next change I would not worry about it. Normal cleanout of the engine debris.
Old 07-27-2008 | 10:20 PM
Red07SSNA's Avatar
Thanks everybody
Make another mistake like that and you're going to get banned for causing all the posters to go "nuts" trying to figure out what you meant. Don't do it again....
I'm **** when it comes to oil changes. I've always cut apart the metal filters too to check for debris. Usually find small bits of metal -- mostly aluminum from the bearings on a new engine......like others have already posted....just keep an eye on the metal. You'll know when you have a problem!
hacadacalopolis
10-28-2015 06:09 PM
no_ss
10-18-2015 11:58 PM
DANRICKARD
10-01-2015 12:08 AM
Slick_Nick
09-28-2015 09:15 PM
grampss
09-27-2015 08:51 PM
Quick Reply: Pieces of metal in oil filter?
