Please help!!!!
Old 05-31-2012 | 09:59 PM
Austin3565's Avatar
Please help!!!!
When ever i give my car gas it sounds like a bycicle with a aluminium can on the back tire, the noise sounds like its under the hood.I took it to the dealership and the machanic there said he heard the noise but said theres nothing wrong with it. Now im not a mechanic but i felt like that was the dumbest statement ive ever heard.
Old 06-01-2012 | 07:56 AM
hhrfreek's Avatar
Check for loose parts like heat shields, exhaust leaks. Maybe just something vibrating at certain engine rpms
He didn't say what he thought the noise might be?
Old 06-01-2012 | 08:57 AM
Austin3565's Avatar
No actually I never even saw the mechanic in person. The mechanically told the lady at the front desk where I filled out all the paperwork that , and she told me.
Old 06-01-2012 | 12:27 PM
Jsgm08's Avatar
i have the same problem, but sounds like something loose
you should remove you back tire and check for something
Old 06-01-2012 | 01:47 PM
Austin3565's Avatar
But it sounds like it coming from the bottom passenger side of the engine
Old 06-01-2012 | 02:57 PM
bluebalt07's Avatar
Passenger side axle?
Old 06-01-2012 | 03:03 PM
TommyP's Avatar
AWD > FWD
Maybe a broken flex piece on the downpipe?
Old 06-01-2012 | 03:12 PM
Austin3565's Avatar
Would either of those be visible without taking everything apart. And does any body have any good links or pics of where the heat shield is so I can check it too
Old 06-01-2012 | 03:18 PM
ssyellow's Avatar
Damn good chance its the flex section/pipe mentioned above. Someone had the same sound and thats what it turned out to be, even described it the same way.
Old 06-02-2012 | 07:07 AM
Austin3565's Avatar
One of my cousins whose a mechanic said it was an exhaust leak, but i do nt wanna pay out the ass. Whats the general location of the flex
Old 06-02-2012 | 07:44 AM
hhrfreek's Avatar
Look over the back of the engine. The silver cover you see is the heat shield. Just above that you see the header and downpipe connection. The flex pipe is the short ribbed section.
Old 06-02-2012 | 01:08 PM
noorj's Avatar
ZZPerformance - 2.5 inch Stainless Cobalt/Ion Downpipe #ZZ-E25DP
Option 1: (Auto or Manual)
Option 2: High Flow Cat
Option 3: none
Add On: Add Front and Rear Gaskets
Add On #2: prepaid label for cat return
There's all your options you need. It'll help a little with performance and is way cheaper than any replacement.
Old 06-02-2012 | 08:56 PM
Austin3565's Avatar
Got a check engine light, took it to auto zone and the code came up as P0175 it also said "bank 1 too low" what is this nonsence
Old 06-02-2012 | 09:17 PM
Sir_Hiro's Avatar
The P0175 is a Running Rich Code While the bank is to low is a running Lean error..
I get that as well sometimes..when the light came on..did you notice any changes in the car and how it was running? Examples: lack of power on acceleration and some "coughing" or misfiring.
Old 06-03-2012 | 03:32 AM
Austin3565's Avatar
No, nothing new anyways. Same noises that I described in OP. Could the problems go hand in hand. Could the light come on for an exhaust leak.
