please help me understand...
I came across the "performance modifications" thread, and between that, and every "built" LE5 I've seen in someone's signature, it seems that to make more power out of the LE5 that you need either a supercharger setup, a turbocharger setup, or nitrous...
Have I missed something?
Sure boost or nitrous is an easy way to make power, but can you guys not make any significant power increases while keeping the motor's naturally aspirated (w/o nitrous)??
Can't you bump compression, swap cams, get a header, and tune the crap outta the 2.4??
thanks in advance for cluing me in...
I came across the "performance modifications" thread, and between that, and every "built" LE5 I've seen in someone's signature, it seems that to male more power out of the LE5 that you need either a supercharger setup, a turbocharger setup, or nitrous...
boost/N2O is significantly cheaper (and more streetable) if your looking for 200+ whp
i think what he is getting at is why cant we build up to about 250ish whp like some honda engines
the answer is simple... its not that we cant, its that our aftermarket is not a large, making parts much more expensive
that being said, for the money to build the engine, u can go turbo and make much higher numbers for a similar price
On a 4 cyl, boost/juice is where the cheap power is. You could spend a fuckton on an N/A build and still have issues cracking 220WHP. For the same price as building a 200+ WHP N/A car, you could've had a 300WHP+ boosted car.
N/A builds are easier done on large displacement V8 engines... not 2.2L/2.4L 4 bangers. GM did have the 190HP LG0 Quad 4, but GM found it easier and more worthwhile to just use boost.
quantity is irrelevant - the LE5 IS supported by the aftermarket at this time...
With the Quad4 it isn't rocket science to break 200whp, but most Quad4 owners happen to be poor kids who have a Quad4 because that's all they could afford...
But most aren't me...
VIDEO
I was going to write more on the subject, but I don't want to bore you guys;
I am actually surprised that there seems to be so little interest in n/a builds since at this time the aftermarket does support your engines...
I think there's some thing to be said about a nice NA build - I mean the Civic SI now even comes with a 190hp n/a/ engine - I would think that anything which can be done by the honda could be matched by the LE5!?
Ok... please humor this last bit (a tangent at that) here;
If anyone here may have been a Jbody guy in the past, and has any leads on a Torsen LSD (which used to be sold for the Quad4 cars (through GM/Oldsmobile)) please PM me!!!
(I have been looking for over a year already.)
again the former Quad4 guy here nailed exactly why I was thinking this;
VIDEO
VIDEO
My buddies 2.4 bolt on Cobalt destoried two RSXs. Honda's are that fast?
the 2.2L has a 50hp disparity to the newest Civic SI engine;
the 2.4L has a 20hp disparity to the newest Civic SI engine.
Please note, I am not talking the bread & butter engines, (I'm not honda guy btw) I've understood the SI motor couldn't be had in any other Honda car - and the 190hp engine was the whole basis for the SI package.
yes sir.
Last edited by EcoTecDriver; 02-12-2010 at 06:10 PM. Reason: Automerged Doublepost
I put the 2.2L & 2.4L in kinda differnt catagories;
I also thought this was kinda funny. Click this link and scroll down to the Torque part. But also don't forget to look at horsepower. 197@7800. 7800RPM, way too high, way too long.
http://autos.yahoo.com/2010_honda_ci..._spd_mt-specs/
yall say we are supposrted in the aftermarket world? yes we have a lot of headers, intakes, and cat back to choose from but look at cams for instance. for the 2.4 we have JBP tri flow cams and that's it. half the people that ordered them never even got them. so we can basically say that we don't have an aftermarket cam for our cars unless you do custom regrinded cams which would be costly and you really have to know exactly what it is your doing.
i personally plan on doing full bolt ons and PnP my TB, or just going LSJ TB. and after that i guess wait for cams or something. my car is too new to change compression by shaving heads or whatever else. i got 30k miles on it.
Depends. If you know what you're doing, you can do it yourself. I know shops around here charging like $150 if you give them a barehead with flow benching.
On a 2.4, I/H/DP/E/T
On a 2.2, I/H/DP/E/IM/TB/T
uhh not quite... 2.2's dont respond to bolt ons any better then the 2.4's. Both gain just as much which makes them still the same distance apart in performance when fully bolted.
2.2's catch up when you start putting the 2.4 TB's and intake manifolds on them as well. But ive done a highway run against a 2.2 with intake, full exhuast and a tune and i beat him by half a car and i was bone stock.
If you go to the dyno thread as well, you can see a 2.2 with the basic bolt ons, intake, header, DP, catback and a tune, makes in the 150 range, thats what a stock 2.4 puts down. A 2.4 with those same mods, puts down in the high 170 range
