possible ram air idea
Old 08-19-2006 | 02:45 PM
savior's Avatar
have a CAI and then remove one of the fog lights to creat a more direct, ram-air like, airflow.. is it possible or would i need to fabricate something
Old 08-19-2006 | 06:13 PM
8cd03gro's Avatar
it wouldn't do alot and it would just make your car looked fucked up.
Old 08-19-2006 | 06:38 PM
biohazard's Avatar
Get low
do this, if you dont use your fogs diconnecti them.... make your fog light infront of your intake to you can snap it in and out,... when you drive around town theyll be dummy lights, at the strip, pop the one out
Old 08-19-2006 | 08:43 PM
trashline's Avatar
I wouldnt waste your money. The benefits become greater at higher speeds the faster you go the better. from idle to 60 mph or so you wont see a benefit. on highway you might. I messed with ram air systems on other cars with it just ending up me wasting money. The only real benefit is your pulling cold air and if you have a CAI thats your best bet. You cant have any restrictions in the ram air. like removing a fog light and putting the filter behind it. if you created dual ducts into a box that air could compress slightly and force itself into the intake you might benefit this is the setup i had. And it helped way up top, where benefits can only be seen at the track.
Old 08-19-2006 | 10:58 PM
stlurbanpunk's Avatar
i was looking in my race car book and saw that the brits use this type of front spoiler (on saloon cars) to force more air to cool the brakes. its positioned right under the front bumper and radiator. perhaps you could try that, just like a sheet of thin metal angled into the wind and directed to the air filter...
Old 08-20-2006 | 12:04 AM
06G5GT's Avatar
Doing that would make it easier for the filter to get wet. I don't think I'd be risking that for such a truly tiny gain in power.
Old 08-20-2006 | 11:30 PM
celicacobalt's Avatar
look under the hood of the RK sport ram air hood, it uses the scoop to direct airflow into the air filter on the 2.2 and 2.4
Old 09-11-2006 | 03:06 PM
panblackrose's Avatar
I did a home-made short ram. Made a big difference in all areas, especially toward top end when you hit 5500+ and it roars. The only issue was fabricating part of the intake to accept the MAF sensor. I've noticed that every couple of days the check engine light comes on and I lose a little power, like the ECU noticed the change in airflow and said f$*k you . Then again, the car is OBD II... The only way to get it back to normal is to switch to the stock intake, which I hate, and keep resetting the ECU by disconnecting the battery if i keep the new intake.
Old 09-11-2006 | 03:20 PM
PpAzZ1101's Avatar
Umm...
1) Short Ram Intake and Ram Air are two totally different concepts.
2) Many 2.4L Cobalts are running aftermarket intakes with no CELs. That is not the only way to clear a CEL either. You can clear the CEL with any OBDII scan tool. You can also clear it with HPTuners.
The reason you're probably getting a CEL is not because of the airflow. I've only had one code thrown due to my intake (lean code). You're probably getting the CEL because of the custom mount for the MAF sensor. The sensor might not be sitting snug and therefore causing the ECU to throw the code due to poor readings. Do you know what codes you're getting?
Old 09-11-2006 | 03:26 PM
06blackg85ss's Avatar
Inhale made his own ram air box... it actually works top end too... he was keeping up with me when I had a 3" pulley and he was stock....
Old 09-11-2006 | 04:00 PM
AlphaJaguar5's Avatar
Some retard on here took a velocity stack and mounted it to his front bumper and took flex piping from pep boys and ran it to his CAI. It looked really funny, there should be some pics of it on here somewhere.
Old 09-11-2006 | 04:08 PM
slowion2's Avatar
you mean that wasn't you?
actually, if something like that above was used only at the track with a straight path to the throttle body and a maf provision, it would work alright, but if it's just putting air at the filter it's not going to net as large a gain as the person was anticipating
Old 09-11-2006 | 04:10 PM
LewiSS's Avatar
The RK Sport Ram Air Hood should work with the GMPP intake, but wouldn't have any effect on the stock air box. You need to seal the intake to the under hood ducting so the filter is forced to breathe through the scoop and not pick up ambient air from under the hood. For true hood induction, you'd also have to block the stock air intake that comes through the fender into the bottom of the stock air box. The all the air the engine is using comes from the hood scoop.
As for ram air, most scoops that close to the hood are in the boundry layer and not up in uninterrupted air flow. You have to use a scoop like those on a pro stock car to get the inlet high enough. However, even without ram effect, breathing air from above the hood is preferable to air from below the car for two reasons: it's hard to hydraulic lock the engine with a scoop (if you get that much water in the scoop you probably just went nose-first into a lake) and the air is cleaner (it doesn't pick up the grit from the road as bad).
Just my 2 pennies worth, for what that's worth...
-J-
Old 09-11-2006 | 04:17 PM
LewiSS's Avatar
Actually this was accepted practice in Trans Am cars at one time, but they used one headlight bucket (back when headlights were round thingies). As for looking bad, I guess it depends on your age. To me it makes it look like a road racer, because I'm used to that look at the track. I once had an Alfa Romeo coupe set up that way. It was easy with them because the inboard lights were actually auxiliary lights, and one was just in front of the air box intake on the right.
Another post mentions saloon cars using under-the-air-dam brake ducting. This has been quite popular for over 30 years in racing. As recent as the Gen I Neon ACR (I have a '96 with a PT Cruiser engine), Chrysler left out the fog lights and said it was for brake cooling. Trouble was, there is a big wall just behind the air dam opening that stops the air from reaching the brakes. So much for function. It was probably just for looks so you can tell an ACR from a cheapo.
-J-
Old 09-16-2006 | 11:41 PM
Gazoo0's Avatar
I'd be careful putting the Intake closer to the road. A friend of mine drove through a deep puddle, and Hydraulic Locked his motor, buy drawing water into the carb intake on Pontiac sunbird.
Old 09-17-2006 | 05:54 AM
PpAzZ1101's Avatar
Originally Posted by Gazoo0
I'd be careful putting the Intake closer to the road. A friend of mine drove through a deep puddle, and Hydraulic Locked his motor, buy drawing air into the carb intake on Pontiac sunbird.
LMPAO!!!!!!!!!!!!!!!!!!!!!!!!!
Old 09-17-2006 | 11:10 PM
CustomSS's Avatar
If you are going to go through the trouble of that you might as well just take out your headlight at the track, in fact both. When I use to run my truck at the track I would notice faster times by removing the headlights and cooler running temps. Still though when I say faster times we are talking about tenths of seconds...not a full second drop or anything crazy!
06MetallicBalt
08-17-2021 03:40 PM
10-20-2015 09:56 PM
no_ss
10-18-2015 11:58 PM
DocSvensk
09-27-2015 02:24 PM
OrangeCoba
09-25-2015 06:06 PM
Quick Reply: possible ram air idea
