questions for boosting a 2.4L
Old 06-24-2010 | 05:51 PM
DFZ24's Avatar
Ok first i don't know where to put this thread, here because is a 2.4 or in force induction. but anyways here are the questions
1.how much oil is going to be needed for a the 2.4 turbo?
reason why; because i read in the manual of the car it says that the sc uses approx 2qts more than the N/A
2.same question for the coolant; how much coolant will the car need if the car is going to be intercooled, and what kind of coolant well be used (same one as oem).
Thank you
I try to search, but couldn't found nothing, if someone can advise me or point me in the right direction, I would appreciate it.
Old 06-24-2010 | 06:05 PM
elecblue06's Avatar
if you're going to turbo your car I would recommend getting the oil pan from the sc so that way it has the extra capacity
coolant isnt specific .. if it's a water to air cooler then that depends on the volume of the cooler
if ti's an air to air then you use the standard amount. it really all depends on your setup.. you dont need the lsj oil pan either ..
but you dont need more of either cuz youre boosted
Old 06-24-2010 | 06:55 PM
DFZ24's Avatar
well first i forgot to add is going to be a daily driver or is a daily driver lol, and i got the zzp stage 2 kit
that brings the air to liquid intercooler
Old 06-26-2010 | 04:21 PM
Cherry GT's Avatar
No more oil will be used if you turbo it.
Unless like said you change oil pans.
The intercooler coolant is seperate from the engine colant,
and if I recall it took about a gallon and a half of coolant.
turbochargedss2012
09-20-2023 12:17 PM
brandon04
10-21-2015 07:04 AM
Extremespeed
09-29-2015 04:34 AM
Iceberg
09-28-2015 01:31 PM
09-26-2015 06:44 PM
Quick Reply: questions for boosting a 2.4L
