Roxanne Gets Built
Old 03-22-2016 | 12:02 AM
ThatNASS's Avatar
Roxanne Gets Built
I have a 2007 LE5 that I would love to boost. I need some help with an exhaust manifold or a turbo kit! Any suggestions would be super duper helpful!!
I am hoping to put her on coils this summer new wheels and tires with a little bit of wheel poke.
I am hoping for about 400whp. If there is anything anyone could tell me please let me know!!
Any help is appreciated!
Old 03-22-2016 | 12:16 AM
Coba's Avatar
Lots of research
It doesn't just happen.
It will take time and money.
Im already 3k into mine
400whp is not an easy number
If you want easy and inexpensive with a good reliability
You should look at the zzp 2.2/2.4 turbo kit
It will get you started and only 2,200 dollars.
That's where you should start.
Post pictures of your car when you get a chance.
If your auto I don't know how much abuse they can take..
Old 03-22-2016 | 12:26 AM
ThatNASS's Avatar
I am manual, I am going to go stage 2 or 3 clutch, I don't quite know yet. I know I am going to need some bottom end upgrades definitely. Unless you don't think so. It seems to be a very healthy engine. Except wiring is really bad since it is a salvage and the wiring just looks like someone threw it together.
I saw the 2.4 turbo kit. I'll look into it and see if I can afford it anytime soon. Definitely need to get some more hours in at work.
Old 03-22-2016 | 11:16 PM
ThatNASS's Avatar
The engine bay definitely needs some cleaning.
Sitting pretty before the body work
The pretty front
Old 03-25-2016 | 02:26 AM
Ecotecftw's Avatar
How many miles? If it's high miles I would recommend doing a compression test before adding that much power. Sharp car though.
Old 03-25-2016 | 04:51 PM
ThatNASS's Avatar
It has 89xxx miles on it.
Wtsf_hc@yahoo.com
06-16-2016 02:42 AM
Jerden47
04-14-2016 03:15 PM
Ryan@zzp
ZZ Performance
03-19-2016 03:01 AM
Raptorunbound
03-17-2016 01:10 PM
GRok25
Wheels and Tires
03-15-2016 09:49 PM
