Running 91 octane instead of 87
Old 07-16-2012 | 01:35 PM
chevygirl2006's Avatar
I've had 93 in my car for 7 months.
Old 07-16-2012 | 01:36 PM
And my car is having a terrible rpm issue. The rpms bounce up and down really bad during shifts and I can hear it in my exhaust. My gas mileage drops a little every day. And I'm thinking my tune could be causing this.
Old 07-16-2012 | 02:11 PM
Gelladuga69's Avatar
I was gonna say bad gas, lol.
Yeah, you should get your tune looked at.
Old 07-16-2012 | 03:01 PM
noorj's Avatar
I wonder how much more timing it would take on E85 compared to 93. Someone NA should test this
Old 07-16-2012 | 03:34 PM
Mindrot's Avatar
I ran 93 when NA for over 3 years with no issues. Your problems are elsewhere. Check the throttle body, change fuel filter, etc. Or like mentioned before get the tune relooked at. Any codes?
Old 07-16-2012 | 05:07 PM
That's what I'm doing right now
Old 07-16-2012 | 05:43 PM
Mindrot's Avatar
Something I've learned about this car is that an issue is normally the result of something really really stupid
Old 07-16-2012 | 06:08 PM
I didn't do nothing
Old 07-16-2012 | 07:01 PM
turbosmart4's Avatar
Don't get gas from grocerie stores...
Old 07-16-2012 | 07:26 PM
Mobil and Shell is all that goes into my car.
Old 07-16-2012 | 07:31 PM
  #36
Texaco and chevron in mine. Its all about that techron
Old 07-16-2012 | 07:53 PM
  #37
Mindrot's Avatar
I didn't do nothing
Don't have to.. Fuel Injectors can fail, Coil packs can fail. I'm just saying that the root of your issue is probably something failing
Old 07-16-2012 | 08:38 PM
  #38
I changed my plugs and coils like last month. Well apparently my car is slipping in 4th gear and the tune had nothing to do with it. I'm going to try to change my transmition fluid and filter and see if that fixes it if not its time for a new tranny
Old 07-16-2012 | 08:53 PM
  #39
Mindrot's Avatar
How many miles on the current fluid? That sucks to hear :/ I've had issues in the past with my 4t45 but it was tune related.
Old 07-16-2012 | 08:56 PM
  #40
Twoozofjuice's Avatar
hey mindrot what type of power are you making? and do you have any internals built up or whatever? im thinking of trying e85 after I get a badmab header but i hear the 06s cant really take much idk lol
Old 07-16-2012 | 09:18 PM
  #41
I don't think the fluid has been changed honestly. I got the car with 63k and I've had since jan 2010 and now it's about to hit 90k. I haven't changed it. And The place we got it from didn't say if it's been changed. The only way to know is to check the fluid. But we couldn't find the dip stick.
Old 07-16-2012 | 09:39 PM
  #42
Mindrot's Avatar
There isn't a dip stick. There is a plug you can take out near the passenger side of the trans. It's probably low on fluid so I doubt you'll be able to check. When I did mine at 100k (50k intervals) i didnt bother checking. Just drained it and filled her back up. I change it every 50k due to the traffic abuse my car goes through.
Old 07-16-2012 | 09:40 PM
  #43
Mindrot's Avatar
High 200's.. I need to dyno it to know exactly what I'm at. Motor is bone stock. These motors can handle power if they have been taken care of. I keep up with fluid changes and don't beat the living **** out of it. 117k miles and going strong.
Old 07-16-2012 | 09:48 PM
  #44
Ya I'm changing the fluid this weekend. And trust me I don't drive it hard. It's my baby
Old 07-16-2012 | 11:28 PM
  #45
what exactly is driving hard? like stepping on it once in a while or like always stepping on it. I try n do grandma driving whenever I can and only really step on it once in a while when I wanna hear the whine
Old 07-16-2012 | 11:31 PM
  #46
Driving it like u stole it pretty much.
Old 07-16-2012 | 11:37 PM
  #47
should be good then...im thinking of doing it. if it blows up imma take out the sc kit and switch my car with yours overnight
Old 07-16-2012 | 11:46 PM
  #48
mtbrent's Avatar
A good solid tune makes a big difference in the long run as well!
Old 07-16-2012 | 11:48 PM
  #49
Haha ya right. Our cars look completely different
Old 07-16-2012 | 11:51 PM
  #50
1 lip...lol ill just take your engine then and replace it with mine lol
Quick Reply: Running 91 octane instead of 87
